I assume they achieve it the same way they achieve 20000mAh 18650 lithium ion batteries: by lying.
Ok, it’s not exactly the same: you can boost the gain on a tiny sensor the same as on a big one. But the noise will be much, much worse. So the resulting images will either be way noisier than the already super noisy images from the A7S at that ISO, and/or they’ll apply even more severe noise reduction, which will render them with even more watercolor effect than the already very water effect riddled images of the A7S at that ISO.
Yes, it’s possible for different noise reduction algorithms to produce better results than others, but miracles are not possible.
Digital sensors do not have a “native” ISO. The ISO is basically a gain setting for the readout amplifiers. Nor is there a real or theoretical limit to ISO as such; it’s just the tradeoff of signal to noise. Eventually your signal disappears into the noise. Before that happens, you choose a balance of sensitivity to noisiness.
