Author Topic: How do you protect yourself from ebay sellers selling broken gear as used?  (Read 5543 times)
Offline cdevTopic starter
Is the fact that something is sold "used" mean a buyer can always return it, if it doesn't function fully, even if the seller claims they said it was untested in the ad. (but also claimed it was 'used' and not 'for parts of not working'?)
Especially if the piece of hardware uses parts which are 'unobtainium',  do you think it should be returnable at the seller's expense if its sold as 'used' but is actually broken enough so that when the buyer attempts to use it or test it its broken and requires repair?
That is the way I interpret the ebay terms.
The need of "specialized equipment" to test or use electronics doesn't absolve the seller of responsibility for an item working if its sold as "used", or shouldn't.  If they don't have the ability to test something at some basic level, (especially given that now they can usually find beginner's hardware on ebay adequate to verify basic operation for very little) they shouldn't sell it as 'working'.
That needs to be a clear boundary there.
« Last Edit: November 15, 2017, 03:48:56 pm by cdev »
Offline HighVoltage
Re: How do you protect yourself from ebay sellers selling broken gear as used?
« Reply #1 on: November 15, 2017, 04:27:51 pm »
My method is to ask the seller lots of questions.
And still, I have bought broken and none repairable equipment on ebay and it sucks!
On the other side I have found almost "like new" equipment so cheap, I sometimes could not believe it.
So, at least for me, it has gone both ways and is overall in good balance.
Offline Tomorokoshi
« Reply #2 on: November 15, 2017, 04:46:03 pm »
I take it as given that it probably doesn't work. If perhaps 75% of the dollar value of what I spend results in working equipment, then I'm satisfied enough. For most of the rest I'm able to repair it either relatively easily, or it becomes yet-another-not-enough-time-but-it's-interesting-so-nothing-lost project. I justify it as "professional development".
Being ebay, a couple things I look at are the overall rating of the seller along with overall volume. High-volume sellers might not be able to answer detailed questions, but if their ratings are good, then the equipment might be workable.
Low-volume sellers may be able to answer questions, but half the time they have no idea what they are selling anyway.
Study the pictures closely. Clear? High-resolution? Proper details? I don't trust anything with stock photographs. A proper listing should have at least 5 or 6 pictures showing all the controls, ports, and labels.
In one case I returned equipment to one of those used test equipment sellers. They clearly called it functional when it wasn't, and they left other things out of the description that showed they hadn't tested it at all. It got returned at their expense. It didn't show up again on ebay, so I expect it got scrapped. Too bad, because I would have been willing to take a partial refund and fix it instead.
Online nctnico
« Reply #3 on: November 15, 2017, 05:16:36 pm »
Answer to the title: don't be stupid or naive so do your research and homework!
« Reply #4 on: November 15, 2017, 05:44:36 pm »
For example, I would really like to get a precise universal counter and there are a few ones out there which are now many years old and when broken they are sometimes quite fixable and sometimes basically you need to combine several non-working units.
Which in my opinion makes them almost worthless at that point. I think that if they are dishonest enough to sell a nonworking unit as working, they should expect to either get it back or eat the cost completely if you get it, have it be not working make a complaint to ebay, and it rules in your favor.
So, recently I found a counter, made what I considered to be a fair offer on it- and wrote into the offer if it was working fully, (which "used" is suppose to imply so it was redundant, still, I can't afford to get stuck with a worthless piece of broken equipment at a working equipment price)
if it was working which they said they wanted to accept if I accepted that they had not been able to test it, also. Then I made it clear that a condition of the sale was that when I got it I would test it using the procedure in the service manual and if it didn't work didn't want it. Then they balked.
Offline Mr. Scram
  • Display aficionado
« Reply #5 on: November 15, 2017, 06:04:23 pm »
Why would you need to protect yourself? If it's broken, it doesn't fit the "used" description, so the seller has to refund.
Offline CatalinaWOW
« Reply #6 on: November 15, 2017, 07:51:44 pm »
As an occasional seller of used gear, Ebay's options don't give me any good options.  I wish there was another category - "used with defects" or something similar.
Technically "used" has to be "fully functional" with only minor cosmetic problems.  To use the automobile world as something almost everyone can identify with - if I had a car with a perfect engine, perfect transmission, perfect suspension, good tires, perfect heat and air conditioning with good upholstery and paint, no dents or missing trim, but a non-working radio I couldn't call it used.
But to call this car non-working for parts only isn't right or descriptive either.  Anyone looking for a working car would tend not to even look at the description of this car.  In fact many would use Ebay's filtering functions to eliminate this listing from their search as they have no interest in mechanical repair.
In the test equipment world I don't have the equipment to fully verify everything on anything but the simplest of equipment.  Even there I can't provide traceability on calibration.  So technically I can't sell as used a multimeter, even if I have checked every range and function and they all seem to be accurate.  I don't have documented proof that it meets original specifications.
The way I deal with this is to list what I have as "used" and describe what I have tested and what the results are.  In some cases this means little or nothing, but in most cases I can verify that the equipment is generally working as I would expect it to.  Pictures of the meter performing key functions are included.  I only use the "not working, for parts only" category for instruments that truly aren't working.
But I don't allow returns and this is stated in the listing.   My thinking is that I have made very clear to the buyer what he or she is getting.  The prices I get are lower than many ask.  This is the trade off that I and the buyer are making.  I get less money, but don't have to set up as a full refurbishment shop.  The buyer pays less, but takes some chance that a function that is of interest that has not been tested is not working.
So far this has worked for me.  I don't know what would happen in case of a dispute since I haven't yet had any.
Offline macboy
« Reply #7 on: November 15, 2017, 08:32:09 pm »
"With Defects" really means "Requires Repair". There already is a category for that: "For parts or repair". You can describe the specific defects whether large or small, in as much detail as you feel you need to, in the item description. Then the buyer can decide whether they are acceptable or not, and bid/buy accordingly.
Used means used. Maybe with scratches, wear and tear, etc. but fully functional is not optional. For anything sold as used, the buyer is fully protected by ebay's buyer protection. As a seller, you need to understand that listing as used means you assume the risk of the buyer invoking buyer protection. Price your item accordingly. I for one am very glad that ebay is super strict about this and backs buyers when they get screwed by sellers who are either too stupid or too greedy to properly list a broken or unknown condition item in the parts/repair category. It is far more difficult for a buyer to succeed with buyer protection claim in the parts/repair category.
To answer the OP question again: you are protected. If it doesn't work then it doesn't fit the "Used" description and ebay will back you.
(Dave himself learned this the hard way a few years ago, selling a scope. He tested it and thought it worked great, listed it as used. The buyer found a functional defect and invoked buyer protection, and Dave took the hit. Big thread here somewhere about that.)
Offline Mjolinor
« Reply #8 on: November 15, 2017, 08:49:23 pm »
As a buyer it is always caveat emptor.
As a seller you cannot win, ebay is against you from day one.
I sell a few things on ebay and I buy loads of things. Favourite search string (faulty, spare, spares, repair, repairs, part, parts).
I sold a laser cutter that was damaged in shipping, it had dents but was absolutely fully functional. It was pick up only so before anyone paid they could see.
I still got non +ve feedback because the buyer complained about it having dents.despite the fact that every single dent was photographed and documented in the listing and that he had seen it before buying.
The world is full of morons and all of them hang out on ebay.
Offline ChrisLX200
« Reply #9 on: November 15, 2017, 09:10:28 pm »
I was interested in a 465B listed as 'used', and the photos just showed the thing with no display. I asked if the display was working, and would he mind just switching it on - and if it was not too much trouble could he also connect the probe comp to channel 1. He replied he was in no position to test, not even to switch it on which he refused point blank despite insisting that other [electronic] items from the same source were fine. Needless to say I would have nothing to do with it.
« Reply #10 on: November 15, 2017, 09:18:23 pm »
When there is a grey area between working and non-working sellers should probably sell as 'for parts or non working" to protect themselves.  A while back I bought a GPS that it turned out had a major design flaw (according to the chip manufacturer, Ublox)
In theory it worked but it worked very badly.
So I opened an "item not as claimed" case and had my money refunded.
I agree with CatalinaWow in that it would make sense to have an additional "Used with issues(enumerated)" for the cases where some issues would otherwise become potential problems. I would very much like that because that information would make it much easier to make a good guess as to if something was fixable or not.
Offline CatalinaWOW
« Reply #11 on: November 15, 2017, 10:25:28 pm »
Perhaps in your world all defects require repair.  You would of course fix the radio in the car I describe.  Many others would never use the radio anyway and drive this excellent vehicle for many years.
With the complexity of many pieces of test equipment it is virtually impossible to assure that "everything" works.  Dozens of switches, many with dozens of positions and dependencies on state transitions.  Combinatorially impossible to switch between them.
But you are absolutely right.  Sooner or later someone is going to feel that they can get one over on me and invoke Ebay buyer protection.  And when that happens I will probably just stop selling the excess gear I have.  And there will be more threads about how there isn't anything good out there for sale.   Congratulations to whoever does that.  Maybe I will post pictures of the stuff going to the dump just to entertain the crowd here.
Online Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #12 on: November 15, 2017, 10:45:50 pm »
I use the German eBay a lot.
Many sellers here put items on auction, which they flag as "broken" but then in the description they say that it works or should work and that the "broken" status is for their own protection, as they don't want to be liable or because they cannot fully test it.
While I can understand this position, I imagine that you could use this apparently convincing explanation to actually sell broken stuff. So in the end you don't know what the real status is.
So my approach has always been:
1) Ask as many questions as required and try to gt to know the seller - why is he selling the device, what devices does he normally sell, etc.
2) Do the homework and get to know the most common or probable failures of the device.
3) Never bid more than you can accept to loose on a broken device.
There have been some tempting auctions, but without any certainty of the defect, I could have been looking at a defect of unobtainable components - total lost. The risk was just not worth it.
On other occasions I have gambled. So far, so good - never got anything really bad and globally the good deals more than make up for the bad ones.
But, whenever I gambled, I was pretty sure I knew what the problem was and how to fix it.
Regards,
Vitor
Offline Neomys Sapiens
« Reply #13 on: November 16, 2017, 12:22:06 am »
Regards,
Vitor
I totally concur so far. Then, I also take a look at the exact wording and the other activities of the seller. I mean, I see 'untested' as a 'maybe', but if someone makes well founded statements about more complicated gear and suddenly is supposedly unable to do a function test on a DMM, he wants to sell you a parrot that will not be talking anymore.
I bought a really exotic instrument, that is a stochastic-ergodic functionmeter from the austrian company Norma.
A few tests showed the bird to be deceased beyond doubt. It was advertised as tested. The seller maintained that
the neighbour, who is a retired electrician, had proclaimed it working.
I also experienced the contrary. I bought a complex signal generator, which was DOA. I contacted the seller, who had previously (in the auction) said, that there is no warranty and no takeback. He gave me a full refund and said, that I should keep the instrument. Later I gut it to run.
Of course both buying and selling instruments and related articles on Ebay is a minefield per se.
There are very serious people out there and with some of them I have worked repeatedly. And there are those fellows who steal something out of a scrap container and try to sell it as working. Some even knof definitely that it is not. Most of them you can weed out with a few checks. Often they give themselves away by a simplistic language and lack of grammar (or even unable to type the name of the company correctly). Then you can assume that some (why isn't there a emoji with a fez?) is trying to rip you off. :horse:
Offline HalFET
« Reply #14 on: November 16, 2017, 07:08:22 am »
For sketchy sellers always use paypal, then you can file a paypal dispute against them. It locks up their account for at least a week or two, so they tend to give in fairly easily. Most of the losses I've incurred were due to shipping though, lost a 7.5 digit solartron that way. Also only buy badly broken if you have a service manual or experience with that device.
When selling on fleaBay these days I simply try to include a full service history in the device description, together with current state. If unknown or too complicated to verify completely (e.g. telecom analysers) I sell as-is. Really broken equipment with unobtanium components I gut and sell in parts.
« Reply #15 on: November 16, 2017, 05:44:46 pm »
Use PayPal and a credit card to make the purchase. If it turns up broken or doesn’t work, hit PayPal first. If that fails, it’s not yours so dispute the transaction with the CC company.
Offline IanMacdonald
    • IWR Consultancy
« Reply #16 on: November 16, 2017, 05:54:21 pm »
The rules are quite clear. A used item should at least work to a satisfactory degree. If it does not, then it must be described as faulty, for parts, or the like.
Even if sold as non working it must be complete unless the missing parts are stated.
Misleading listings are also prohibited, for example "Keysight oscilloscope, probes"  where only the probes are offered.
Online nctnico
« Reply #17 on: November 16, 2017, 06:22:50 pm »
Better check your CC terms & conditions because this double insurance is no longer available for the one I have.
« Reply #18 on: November 17, 2017, 01:58:41 am »
I think both buyers and sellers should do their best to disclose and also ask questions that identify potential problem areas, before the sale goes through.
« Last Edit: November 17, 2017, 02:02:50 am by cdev »
Offline Oldtestgear
« Reply #19 on: November 18, 2017, 09:41:26 am »
I sell a few surplus items on eBay. I only offer equipment "for parts or repair" but state exactly what testing I have done in the listing. I might be able to fully test something but it is normally too time consuming & most people will ignore the information.  Most buyers seem to accept this & I do achieve good selling prices for most of the stuff I list.
As a buyer I expect that "used" means exactly what eBay states unless the seller is more specific in the listing about the item. If all else fails then reject it & return. eBay is always on the buyers side in these situations. Have I been burned? Of course but not too often. Fortunately.
Phil
Offline Mr. Scram
« Reply #20 on: November 19, 2017, 01:02:43 am »
Phil
I feel a lot of sellers are trying to manipulate the situation a bit. They'll list the item as "used", but mention that it's sold "as is" or with very basic testing. If it's something like a functioning multimeter with one socket damaged and that's clearly being stated, that's fine. If it's a multimeter and the readings turn out to be wildly out of spec, that's on the seller. You shouldn't sell it as used if you can't confirm basic operation, as that's part of the eBay used definition.
Offline razberik
  • Country: cz
« Reply #21 on: November 19, 2017, 01:13:56 am »
I never protect myself from ebay seller selling broken gear to me.
I deliberately buy broken gear to fix it.
Offline Mr. Scram
« Reply #22 on: November 19, 2017, 01:22:25 am »
If it has an unobtainable proprietary connector or something, then I will take a chance.
If it uses standard BNC jack and IEC power jack, the only reason it is sold as non-tested is that it failed test.
No one sells a perfectly working unit as unknown condition. Boot it up, hook it to a func gen, get waveform/spectrum/whatever readout, totally takes 2 minutes, and even for the most expensive labor, say, $100/hr, that's only $3.33, and the extra value is way higher than that if it's working.
Still, some people prefer to sell everything as is and let other people find out. It's not an unusual model, not in electronics and not elsewhere.
Offline Halcyon
  • Global Moderator
« Reply #23 on: November 19, 2017, 02:17:54 am »
No, not necessarily. Regardless of what ebay/Paypal policies say, they don't trump your country's consumer laws.
For example, in Australia, anything bought at an auction (including online auctions) comes with no consumer guarantees. This means even if the item is broken, faulty or not as described, according to the law the seller has no recourse to either return the item to the seller or seek a refund. However ebay or Paypal may offer a remedy to the buyer, but that's up to them.
However making a "purchase" is covered by consumer laws and in such cases, the seller must offer a remedy (and can't fob you off to the manufacturer). They are also responsible for reasonable costs incurred when shipping the faulty item.
Even international sellers who are selling a product in Australia are bound by the Australian Consumer Law, however enforcing consumer laws can be difficult or almost impossible when it comes to international sellers.
At the end of the day, do your homework, study the photos carefully, ask the appropriate questions (never assume anything) and not only read what the seller has written carefully but consider what the seller hasn't written. Deliberate omissions can be a sign that the seller knows there is something wrong but is failing to be honest about it.
Also do some research and understand the consumer laws in your country and what rights you're entitled to. If your consumer law rights have been breached, the seller must offer a remedy and if they refuse to, ebay should be taking appropriate action.
Offline Mr. Scram
« Reply #24 on: November 19, 2017, 02:24:26 am »
Typically, consumer laws set a minimum to protect buyers. It's quite rare for them to actually explicitly limit the rights of the consumer. Unless it's specifically prohibited to extend the rights of a buyer, eBay is likely free to do so. Their rules don't trump consumer laws, but work in conjunction with and on top of.
