get the ESD safe version of the above, I just threw out around 1kg of plastic containers and bags after filling a single 144 component ESD safe SMD IC organizer last week with op amps and such. Basically an entire large office trash cans worth of plastic. I saved all the ESD foam from the boxes to line the inside of fishing lure divider boxes with TO-220, DIP12+, ETC.
You can fit 3 dip 8's in one of those box dividers, its a bit perilous and you need to align it before closing to ensure you don't bend a lead but it works.
It was beginning to get hard to use SMD components based on just finding them stored in plastic tubs, so I decided to get one of those containers. Factor of 10+ storage space reduction.
Not sure if its the best choice for resistors because they fit in books, but for IC's it is a wise choice.
You can comfortably fit 2x sample dip 8 IC into one of those boxes, 3 = manual alignment First time I can find something in 5 years LOL
It's a bit pricey but anyway if you use quality op amps, ADC, DAC, etc.. totally worth it. That little box would easily cost a very sizable sum to fill with what I have in it.
Also I cleared out 3x 40 compartment adjustable divider organizers so I can have my relays, MCU, etc arranged into a nice formation rather then a digital death ball. So it actually paid for itself by freeing up 3x boxes worth 15$ each in addition to reducing Tupperware pressure from plastic overfill, I basically had fields of unsorted TO220, DIP8, DIP16, DIP40, TO-3, TO-5 filled to max density on stacked black foam in those boxes, now its single layer and properly divided up. I also freed and 'planted' around 10 tubes of DIP logic gates into the freed containers, they were basically just thrown on a shelf in random length plastic sleeve that was totally dilapidated from age (90's 7400/CD stuff).
