Author Topic: How Does the Dyson Motor Work?  (Read 23528 times)
Offline CyberdragonTopic starter
« on: October 22, 2016, 07:57:25 pm »
He apparently doesn't know either. From a link in the comments that led to one of Dave's early rants he shows the box of an early model dyson cordless vacuum. On the box it clearly says "neodymium magnets" meaning it's a brushless DC motor. But in this motor from the hair dryer there is a magnet, but it's not neodymium because it was weak. I doubt a DC motor would work very well with magnets that weak without something else going on. He says it could be a reluctance motor, but then why have any magnets at all? Are they some sort of "easy-start" thing? :-//
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline rob77
  • Country: sk
Re: How Does the Dyson Motor Work?
« Reply #1 on: October 22, 2016, 08:09:49 pm »
it's a 2 pole brush-less DC motor.. it has only 2 poles to get the high RPM (the more poles it has the slower it goes at the same switching frequency).
« Reply #2 on: October 22, 2016, 08:21:36 pm »
Are you saying they are getting 100W of power with a magnet no stronger than a fridge magnet?
*BZZZZZZAAAAAP*
Offline bktemp
« Reply #3 on: October 22, 2016, 08:30:29 pm »
I don't see why not. That motor does not need to generate a high torque, it is optimized for high RPM.
Offline rob77
  • Country: sk
« Reply #4 on: October 22, 2016, 08:36:09 pm »
exactly - the strong magnetic field would be needed for torque not power... i would say the weaker magnetic field is even better to get the very high RPM the impeller needs to move that air volume.
Offline johansen
« Reply #5 on: October 22, 2016, 08:41:31 pm »
reluctance motors can have magnets.. we call them hybrid stepper motors.
anyhow, the motor control appears to be fairly creative. sensorless, but it is probably measuring the rotor position by measuring its inductance.
Offline rob77
  • Country: sk
« Reply #6 on: October 22, 2016, 08:54:32 pm »
i would say similar to sensor-less brushless drive - the winding is let to free-wheel for a moment and the generated voltage is measured. with a 3phase drive it's simple because you can have 1 phase floating for measuring the back-emf while the other 2 are energized.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #7 on: October 22, 2016, 09:43:02 pm »
I'd imagine that at high speeds, a strong permanent magnet  might cause eddy current losses.
With only 2 connections I'm curious as to how they make sure it starts in the right direction.
Day Job: Mostly LEDs
Offline rob77
  • Country: sk
« Reply #8 on: October 22, 2016, 09:53:32 pm »
personaly i would give it a nice pulse to make it turn and measure the back-emf till zero cross - if it goes from positive to zero or negative to zero would tell the direction.. counting 2 zero crosses would give the speed - and with a precisely timed pulse you would change it's direction if needed...and then start to comutate to spin it up (pulse, measure back emf till zero cross, comutate , measeure back-emf...etc...)
« Reply #9 on: October 22, 2016, 10:08:17 pm »
Coluld also be that its stationary cogged position is biased towards one pole.
Offline rob77
  • Country: sk
« Reply #10 on: October 22, 2016, 10:17:48 pm »
that would make it start always in one direction and eliminate the need for detection of direction and reversal of rotation during the startup - would save few lines of code in the micro ;)
but i have no clue how i would achieve that , my imagination has it's limits :D i would say the rotor needs to be magnetically symmetric and that would rest always centered - so no clue how i would bias it towards one of the poles.
Online Zero999
  • 0999
« Reply #11 on: October 22, 2016, 10:44:29 pm »
Shaded pole?
I don't see how it could be done any other way.
Offline rob77
  • Country: sk
« Reply #12 on: October 22, 2016, 10:55:36 pm »
Shaded pole?
wouldn't that create a significant drag at such a high RPM ?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #13 on: October 23, 2016, 04:22:49 am »
Weak magnetic field because back EMF is proportional to field intensity.
If you have a parallel wound DC motor with separate rotor and stator connections, you make it go faster by reducing the current in the stator winding.
Likewise, series wound motors have metric shitloads* of torque, because at low RPM, back EMF is low, so the equivalent resistance of the motor is very low, current draw is very high, and stator field is very high.  Series-wound motors do not have a constant torque to current ratio, but rather a parabolic curve because the rotor current is multiplied by the field current.  (Squaring a negative value also makes a positive number, which is why series motors cannot be ran in reverse: they are also known as 'universal' motors, because they run on AC.)
*A technical term.
Seven Transistor Labs, LLC
Offline amyk
« Reply #14 on: October 23, 2016, 06:04:32 am »
Shaded pole?
Shaded or otherwise only very slightly asymmetrical would be enough to ensure the motor spins in the right direction.
Too bad he didn't try driving it with a waveform of his own...
And that sort of power density isn't so surprising, the RC world has had 100W brushless motors of around that dimension for a long time: http://www.maxxprod.com/pdf/HC2808-xxxx.pdf
Offline Refrigerator
  • Country: lt
« Reply #15 on: October 23, 2016, 06:52:31 am »
But it's a 4 pole magnet.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline oldway
« Last Edit: October 23, 2016, 07:49:12 am by oldway »
« Reply #17 on: October 23, 2016, 07:42:34 am »
4 poles means 2 N poles and 2S poles, so just 2 actual poles. Then you make the stator slightly offset WRT the coils ( cut 2 of the laminates on the one end to be slightly shorter so a larger air gap there) and, just like a regular shaded pole motor, it will only run in one direction.
You get 400Hz aircraft blowers with the same size, and those suckers do move air, though they also scream doing so.
The following users thanked this post: rob77
Offline rob77
  • Country: sk
« Reply #18 on: October 23, 2016, 08:09:58 am »
that would make sense ;) thanks  :-+ i think that's how it's done. a shaded pole would induce a significant drag at that speed. and a software solution in the controller would delay the spin-up.
Online Zero999
  • 0999
« Reply #19 on: October 23, 2016, 09:07:46 pm »
Technically it's not a DC but an AC motor.
The person who created the video appears to be pretty clueless. His experiment comparing it to a stepper motor is BS. Of course a stepper motor is optimised for high torque at low speed, so it will generate a relatively high voltage when its shaft is turned slowly. The Dyson hair drier motor is designed for high speed, so it will generate a fairly low voltage, even if turned faster than the stepper motor.
« Last Edit: October 23, 2016, 09:41:17 pm by Hero999 »
Offline rob77
  • Country: sk
« Reply #20 on: October 23, 2016, 09:15:39 pm »
yes correct, brush-less DC motors are technically AC motors.. everyone knows that, yet everyone calls them brush-less DC motors ;) and technically the brush-less DC motors are the closes relatives to stepper motors. and technically stepper motors are also AC motors... aren't they ?
the reason for that might be that a brush-less DC motor requires a controller to be operated (which does the switching and also might do sensing of rotor position), therefore the motor and the controller can be considered as a single unit - and that unit is fed by DC.
Online stj
« Reply #21 on: October 24, 2016, 06:26:00 am »
good, now that that is settled.  ;)
how do they keep the bearings from being destroyed at that speed?
Online Zero999
  • 0999
« Reply #22 on: October 24, 2016, 08:07:00 am »
I don't see how you could sense the direction of a symmetrical single phase motor, without another winding slightly out of phase, a Hall effect or optical sensor. When the motor is unpowered, the pole of the rotor will be aligned with the stator. If a field is applied to the stator to flip the pole, it could go in either direction and the generated back EMF will be identical, thus there is no way to control the direction.
If the motor is made to be asymmetrical, then it could be done but then it's easier to just design the motor so it always starts in the same direction, without any complicated software control algorithm.
Offline rob77
  • Country: sk
« Reply #23 on: October 24, 2016, 09:55:29 am »
yes you're right about the back-emf, so it's not doable that way.
and i think SeanB provided the most plausible solution for the start in the same direction.
Offline johansen
« Reply #24 on: October 25, 2016, 08:06:49 am »
so for what its worth, i've never run across a shaded pole motor with a variable air gap. meaning, the air gap across the section after the shorted turn is the same as the rest of it.
and i've never run across a single phase 400hz aircraft blower motor....
nor have i ever heard nor read about causing the saturation of half of the pole piece as a way of generating a rotating field.
the math behind a shaded pole motor is rather nutty, the same sort of mechanism is going on in a regular induction motor that have a start coil, (high resistance) but they have no start capacitor (btw, adding a capacitor to these motors should increase the starting torque)
