Technically it's not a DC but an AC motor.
yes correct, brush-less DC motors are technically AC motors.. everyone knows that, yet everyone calls them brush-less DC motors
and technically the brush-less DC motors are the closes relatives to stepper motors. and technically stepper motors are also AC motors... aren't they ?
the reason for that might be that a brush-less DC motor requires a controller to be operated (which does the switching and also might do sensing of rotor position), therefore the motor and the controller can be considered as a single unit - and that unit is fed by DC.
Unipolar steppers and switched reluctance motors can be driven with DC, there's no reversal of the current through the windings. On the other hand, something like this Dyson motor is clearly being driven with an AC waveform.
I found an examination of another Dyson motor, one from their vacuums:
https://www.experimental-engineering.co.uk/dyson-dc35-digital-teardown/
In this image you can clearly see what looks like an asymmetrical (and rather large) pole gap.
There is a Hall sensor for the motor in the
picture at the same site mentioned by amyk.
It looks like a Siemens SLIC-HALL
TLE 4945L device.
The rotor may have an asymmetrical magnetic field (one pole larger than the other perhaps) or the stator pole asymmetry may have something to do with it. However I think it would be a good idea for someone with a good long recording memory scope to examine the waveforms to the H-bridge, and from the stator winding and Hall sensor.
While the impeller on these is somewhat directional there are many simple/cheap aquarium water pumps with straight vanes that are self starting in either direction I still believe it would be instructional to find out how Dyson
selects or determines the designed direction to get the best efficiency.
The best would be for a simple circuit that could drive the motor with the H-bridge signals and the Hall Effect feedback without the Dyson legacy battery issues. Having a small circuit that could take any power tool battery pack and run it down to 18V as fast as selected would make the vacuums recyclable and the fans repurposable.
