Author Topic: Microwave oven - magnetron failure  (Read 1462 times)
Offline DTJTopic starter
« on: May 14, 2023, 01:30:54 pm »
My microwave decided to arc up and fail yesterday.
It's old and the mica screen has seen better days. I assume that grease and food vapours built up to the point arcing occurred on the nose of the magnetron.
It melted the nose and also melted through the side of the microwave cabinet into the cooking cavity.
Nothing overly technical but I thought it was interesting.
Offline Brumby
Re: Microwave oven - magnetron failure
« Reply #1 on: May 14, 2023, 01:37:03 pm »
Oooohh.  Good fun.   ;D
« Reply #2 on: May 14, 2023, 01:40:13 pm »
It made a nice loud hum when arcing and the inside wall of the cooking cavity was glowing red near the magnetrons location.
Offline Gyro
« Reply #3 on: May 14, 2023, 08:41:56 pm »
That's an impressively burned antenna! Yes, grease build-up on the waveguide window and also running empty / with dry contents can cause that. All is not lost though. They are replaceable, a simple pull-off, push on. You can find them on ebay (search 'magnetron cap'), pick one with the same shape hole (triangle) in the top - I don't know if this is strictly necessary but there must be a reason why they come with different hole shapes.
It sounds as if the magnetron itself still has plenty of output power available!
Best Regards, Chris
« Reply #4 on: May 15, 2023, 01:44:09 pm »
Ooops. I pulled the old one apart and tossed it all except for the neat little synchronous platen drive motor.
It's burned a hole through the cabinet wall anyway!
Offline strawberry
  • Country: lv
« Reply #5 on: May 15, 2023, 04:36:03 pm »
it happen because of some dirt or mica failure
« Reply #6 on: May 17, 2023, 08:27:59 am »
The mica window between the magnetron and the food cavity?  It was pretty bad condition, I'd replaced it about a year ago.
Offline EPAIII
« Reply #7 on: May 20, 2023, 09:47:47 am »
That's neat. Did you get any video?
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
« Reply #8 on: May 21, 2023, 04:27:15 am »
I was too busy trying to reach over and unplug it so I could take it outside. It started smoking quite a bit.
