Author Topic: How it's made,Oil Pressure Sensors: video, includes screenprinted PCB tracks  (Read 1671 times)
Offline codeboy2kTopic starter
I just came across this video and I thought I would share it :)
It's about the construction of oil-pressure sensors, which to my surprise, reads the pressure directly on the silicon chip.  There's a portion where they screen print a silver-palladium alloy onto a ceramic carrier, and then pick and place some passives on the pads.  I thought that was pretty cool to see the screen-printing and it was a very quick way to get dozens of little circuits printed.  Why isn't that a home-process yet :) I'd certainly pick screen printing over chemical etching, but it's probably still too expensive even with the reduction in steps.
Offline Tandy
  • Darren Grant from Tandy, UK.
    • Tandy
What is this soddering they speak of?
For more info on Tandy try these links Tandy History EEVBlog Thread & Official Tandy Website
Offline rs20
Thanks for sharing, that's a really elegant process -- I especially liked the way the o-rings and pushed down, and then the whole thing is crimped in that state to maintain the preload. Lovely stuff.
Offline T3sl4co1l
    • Seven Transistor Labs
It's called hybrid construction.  You can do PCB stuff and IC packaging stuff, all in one place.
I'd suspect the screened connections are lower tolerance than photo-etched (compare the tolerance on PCB silkscreen to soldermask or copper).  But certainly good enough for placing some chip components on.
Other methods include direct nichrome (or other resistive alloy) deposition, followed by photochemical or laser etching, to get precise shapes and controlled resistances.  Laser drilling to apply vias on the ceramic substrate; alternating layers of enamel and metal paste to get multilayer construction; etc.
No idea what the typical NRE is, but I'm sure it's not small.  When you're making a billion of a thing, like automakers do, you can negotiate astonishingly low prices even for things like this.
Seven Transistor Labs, LLC
Yeah, I've seen some of the multilayer hybrids used in some HP gear, and others as well.
This oil pressure sensor is not a complex hybrid, but I've never seen the construction in a video before.  I'm sure there's one out there somewhere showing the process for a more complex hybrid as you described.
Post a link if anyone has one :)
Cheers
