Author Topic: Source for iPhone/Ipod cable assemblies with more than USB?  (Read 2189 times)
Online N2IXKTopic starter
Looking for a good quality cable to use on an iPod/IPhone dock type device. 30 pin docking connector one one end, flying leads (or whatever) on the other end.  I need the USB pins (power and data) and the audio line outputs pinned through.  USB only cables are easy to get,  but harder to find when I need the audio lines too.
Alternatively, anyone know a source for a DIY installable 30 pin plug i can install on my own cable that will take fairly heavy use and doesn't need $$$ special tooling to install?
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline Richard Crowley
  • KJ7YLK
Re: Source for iPhone/Ipod cable assemblies with more than USB?
« Reply #2 on: May 30, 2014, 11:38:09 pm »
Yeah, I saw that one. No shielding, no strain relief, looks like total garbage.
  • KJ7YLK
« Reply #3 on: May 31, 2014, 01:26:47 am »
It worked great for me.  If you can't figure out your own shielding and strain relief, then you are limited to waiting for others to do it for you.  Good luck with that.
