Author Topic: How many EEs know this basic thing?  (Read 3094 times)
Offline terranceTopic starter
« on: May 08, 2024, 09:28:44 pm »
A device can't reach multiple maximum ratings at the same time, and ratings have their conditions.
eg.
LM1117 ratings
800mA,
15V
TJ 125degC
Does not mean
1. It can work at 15V input and regulate 800mA output at the same time.
2. I can regulate 800mA at 125C ambient temperature
Offline Andy Chee
Re: How many EEs know this basic thing?
« Reply #1 on: May 08, 2024, 09:55:20 pm »
Isn’t that why we study the device data sheet’s “safe operating area” specification?
The following users thanked this post: Brumby, tooki
Offline Sensorcat
  • Independent Sensor Consultant
    • Sensorberatung
« Reply #2 on: May 08, 2024, 10:01:56 pm »
The "absolute maximum ratings" section of a semiconductor datasheet tells nothing about how to operate the device. It tells that you have to expect destruction if you exceed any of the limits. In order to find the limits for correct operation, you have to look at all the other sections. The tables usually specify the conditions for each specification value in one of the columns. There's no magic in this, the datasheets follow the same conventions industry-wide, but you must be familiar with the way specifications are given, otherwise: :-BROKE
The following users thanked this post: SeanB, tooki, terrance
Offline Someone
    • send complaints here
« Reply #3 on: May 08, 2024, 11:05:19 pm »
I see you've been working with similar colleagues to me. Even ignoring the footnotes and * against all the specifications.
The following users thanked this post: terrance
Offline Alex Eisenhut
  • Place text here.
« Reply #4 on: May 09, 2024, 12:14:21 am »
Also applies to scope probes. 600V at DC doesn't hold at 100s of KHz. Poof!
Offline Whales
    • Halestrom
« Reply #5 on: May 09, 2024, 02:40:49 am »
"Reaching" maximum ratings is misleading.
If you exceed maximum ratings: permanent chip damage will occur, preventing normal function when conditions return to normal again.
If you are less than maximum ratings: permanent chip damage or misbehaviour may occur.
Offline Someone
« Reply #6 on: May 09, 2024, 05:17:23 am »
I wouldn't put it that certainly as binned/selected parts can work indefinitely outside the "ABSOLUTE MAXIMUM". But AD do clarify their interpretation:
https://www.analog.com/en/resources/analog-dialogue/raqs/raq-issue-50.html
Offline Berni
  • Country: si
« Reply #7 on: May 09, 2024, 05:26:31 am »
That is NOT how you are supposed to use the Absolute maximum ratings!
The purpose of that table is to set limits for each parameter where exceeding any of them could cause permanent damage to the device. If your design causes the device to operate close to those parameters then you fucked up by designing it wrong. They give you this table just so you can make sure you can avoid these numbers (even for short peak pulses).
The actual numbers you want to work with are in the table labeled Operating conditions. These are the numbers that are characterized by the manufacturer to be within spec. It puts limits on where you are allowed to operate the device for long periods of time and expect it to work correctly.
For linear regulators you can't just take the max current. Not only does it depend on the input voltage, but it even depends on your PCB layout. This is why they specify a Tjmax and the thermal conductivity of the package. You have to calculate the thermal conductivity of your PCB, add it to the package conductivity, calculate the max ambient temperature inside the box, use that to calculate the Watts of disipation available, calculate the voltage drop.... and only now can you calculate the max current for your specific design. The datasheet gives you the numbers so that you can do these calculations.
EDIT: But in practice you don't actually calculate this to exact numbers every time. You just take rough approximations to make sure the LDO is far from Tjmax. it doesn't matter if it runs at 50 °C or 90 °C at your design current. As long as it is not dangerously close to Tjmax
« Last Edit: May 09, 2024, 05:30:57 am by Berni »
Online elektryk
« Reply #8 on: May 09, 2024, 08:24:03 am »
Beside SOA sometimes there's also "power derating".
Offline ebastler
« Reply #9 on: May 09, 2024, 08:52:25 am »
To get back to the OP's question in the thread title, I sure hope the answer is "all of them".
The following users thanked this post: oPossum, bookaboo, tooki, Gyro, 2N3055
Online pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #10 on: May 09, 2024, 09:55:47 am »
On a similar note:  I made an entire video explaining why max power supply output does not equal max output voltage * max output current.
And then when some people still weren't convinced,  I wrote a MATLAB program to demonstrate :)
Edit:  we also turned this into a webpage:
https://www.rohde-schwarz.com/us/products/test-and-measurement/essentials-test-equipment/dc-power-supplies/understanding-derating-curves-_256009.html
« Last Edit: May 09, 2024, 10:00:29 am by pdenisowski »
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: nctnico, tooki, terrance
Offline Gyro
« Reply #11 on: May 09, 2024, 11:41:15 am »
Any that you would hire anyway!
The thread title and post read as if the OP has just read their first datasheet and made a 'discovery'.
Best Regards, Chris
The following users thanked this post: Stray Electron, tooki, 2N3055, soldar
Offline joeqsmith
« Reply #12 on: May 09, 2024, 01:22:54 pm »
Does not mean
First thing that came to mind was high voltage relays.   Worse, as companies are bought and sold, marketing and managers strips details from the datasheets that EE's require.   Don't get me started....   :-DD
Offline SiliconWizard
« Reply #13 on: May 09, 2024, 08:49:36 pm »
TLDR; RTFM.
« Reply #14 on: May 09, 2024, 09:40:40 pm »
Actually it's not about read or not, it's about how people understand how components work.
I saw too many circuit deigns ignoring some fundamental limits....
too many "why my 800mA IC turned into smoke at 200mA?"
« Reply #15 on: May 09, 2024, 09:43:44 pm »
didn't I mention 'Reaching "MULTIPLE" maximum ratings' ?
« Reply #16 on: May 09, 2024, 09:46:11 pm »
My job was wiping these asses for a long while... And they always say "this should be fine, within specs".  |O
« Reply #17 on: May 09, 2024, 09:50:32 pm »
Sorry I did not mean "absolute maximum ratings", I should say "normal operating range"
« Reply #18 on: May 09, 2024, 09:53:36 pm »
Thanks! I didn't mean "absolute maximum ratings". Just too many colleagues and some EEs just keep ignoring limitations they don't "care".
Offline CatalinaWOW
« Reply #19 on: May 09, 2024, 09:57:07 pm »
Did you not see multiple answers responding to how to deal with "SAFE OPERATING AREA".  While many devices do not explicitly define a safe operating area, any EE worth his salt knows that operating under conditions different than those shown as characterized is terra incognita, and requires knowledge of the details of how devices work, what things can limit their operation, and operating environments ranging from heat, to light to EM fields and more that influence both operation and life.
Is your question just a way of finding out how many others have learned the hard way?  I am sure that in some sense or other many of us have.  One of the ways to distinguish good engineers from bad is how often they repeat mistakes, and for those who don't repeat them, how broadly they apply the lessons learned.  Unfortunately there are the other kind.  I once saw documentation where an engineer repeated the same mistake 29 times, destroying that many copies of what was at that time a rare and expensive part.  Never stopped himself, someone else saw what he was doing and put an end to it.  Multiple lessons learned in that situation by folks around this guy, things about how to find and detect such stupidity earlier, and how to control the scope of its impact.
Offline ebastler
« Reply #20 on: May 09, 2024, 10:01:59 pm »
@terrance -- I see you are new to the forum. When you reply to a post which is a few messages back in the thread, it is advised to use the "Quote" link in that post, rather than the "Reply" link.
This will automatically insert a quoted copy of the post you are replying to, allowing readers to understand which message you are referring to. And it avoids the impression that you are mumbling to yourself in a long series of posts...  ::)
The following users thanked this post: thm_w, tooki
Offline Sensorcat
    • Sensorberatung
« Reply #21 on: May 09, 2024, 10:06:24 pm »
As a supervisor of students doing their 1st larger project, you can see the traces of these discoveries in their reports. When they focus on something not worth mentioning for an entire page, it's a 'discovery'.
Online DavidAlfa
« Reply #22 on: May 09, 2024, 10:20:48 pm »
This question is at Arduino hobbyst level, copy&paste, magic happens.
I guess it's your first steps in design so pretty understandable, there's a vast land out there!
It's the Pmax and Tjmax what limits the operation area.
A typical regulator won't be able to cope with more than 0.5-1W just naked, it will overheat.
If you're able to keep it chill with a proper cooling method, you still have to take care of Pmax, the heat the package can transfer to the outside world is not infinite, past this it will overheat internally, even if you attach it to the Eiffel tower during freezing winter.
« Last Edit: May 09, 2024, 10:24:49 pm by DavidAlfa »
Offline Berni
  • Country: si
« Reply #23 on: May 10, 2024, 08:07:07 am »
Yes, it is normal for all of the rating in the "Operating conditions" to apply simultaneously (Unless specifically mentioned in the note to apply under some specific conditions)
You can reach up to the maximum on any of those specs, as long as you don't also exceed the any other specs. This is because not every circuit designer will be running the device under the same conditions. Some need a LDO to drop 30V to 5V, some only do 6V to 5V. It doesn't make sense to limit the designer who only needs to drop 1V to the current to the current of a 30V drop.
This is the same as buying a car with the following specs:
Top speed: 210 km/h
Towing capacity: 1400 kg
Then hitching up a 1000 kg trailer to the car and flooring it up a 15% grade hill. Yet the car only managed to get to 110km/h despite flooring it all the way and not even being at max towing capacity. Does that mean the top speed of 210km/h is bullshit? Why would they sell you a car that claims to do 210km/h if it can't do it in all conditions? Such a rip off.  :-DD
The following users thanked this post: pdenisowski, Sensorcat
Online pdenisowski
« Reply #24 on: May 10, 2024, 09:13:42 am »
Top speed: 210 km/h
 :-DD  That's a fantastic example - thanks!!!
(Although I'm going to have to change it to mph and pounds / tons before I can share it with my friends and coworkers)
