81st week is the first hint that time travel does exist.
If time travel exists, it has to have been already invented. It's impossible for a time machine to come back to the past because the future hasn't happened yet. The future has to happen before, if possible, we can go to the past, as there is nothing that in a way pre-runs the future to check if there is something to come to the past. In away it's like going on one end of a Y fork, with the base being the future, and then to time travel you go back through the other tine.
If you were, however, to change the past timeline in a way that would make it impossible for your birth to occur, unless you were using a time travel method that allowed you to exist in your future while interacting in the past (essentially putting you in a bubble where you exist in your present while you interact with the past) you will not Marty McFly disappear into nothing, as there would be nothing to force you out of the past into limbo. You would just remain there, progressing as if that time line had always existed, just with you existing in it. That being said, there is no way to tell if we have already experienced either of these possibilities. In the future if there happens to be a time traveler from what would have been our future, they are lying as they are from a different future that has come back to our timeline (an event that would be impossible to perceive to us).
See this is what happens when you give a man too much free time, he ponders the meanings and logic behind the universe and ends up confusing everybody. Bugger.
