Author Topic: How to boil water faster  (Read 44906 times)
Online soldarTopic starter
« on: January 08, 2024, 11:31:02 am »
The question was asked in another forum but there were a lot of just plain ignorant and stupid answers and the topic died but I think it might be a good thought experiment. The question is
Is it faster to boil 10 L of water all at once (in a 10L pot) or 10 L of water in 1 L pots successively?
That was the question but, as always, the devil is in the details. If you boil 10 L of water all at once then all the water is boiling at the end whereas if you boil it in small containers then all containers were brought to a boil but at the end only one is still boiling. So let us stipulate at the start all are at room temperature and the experiment is completed when all the water was brought to a boil, even if not simultaneously.
I think bringing the water to a boil simultaneously in several pots would only be feasible with a source of heat for each pot.
I suppose we may need to specify other things like how it is heated (electric, gas, etc) but for now we can just specify the heating power is the same in both cases.
What say you?
Offline Andy Chee
Re: How to boil water faster
« Reply #1 on: January 08, 2024, 11:50:01 am »
This sounds like a surface area/volume problem.
I'm pretty sure the 1L pots will boil quicker, even if all the pots are on the single heat source.
It's almost identical to the ice cube melting problem, which will melt quicker, a massive 10kg block of ice, or 10 x 1kg blocks of ice.
Offline tom66
« Reply #2 on: January 08, 2024, 11:58:42 am »
I would suggest that a submerged element vs a plate element at the bottom of a pot would vary the results significantly, as would stirring the fluid, but my intuition is that assuming a bottom-heated plate (i.e. a normal kettle) it is quicker to boil 10 pots than 1 larger pot.    However, intuition is often wrong!
Offline AndyC_772
« Reply #3 on: January 08, 2024, 11:59:17 am »
I'll make a case for the opposite, that the 10l container boils first.
Throughout the heating process, the heat (from whatever source) is going into a larger vessel, one with a higher ratio of volume to surface area. This means that relatively less heat is being lost from the walls of the pot, and more of it is retained within the water. If we assume the pots have similar proportions, then the larger base will also receive a greater proportion of the heat from the source, ie. less goes straight from the source to the environment, bypassing the pot entirely.
It's the opposite of the ice cube problem. Melting faster means maximising the rate of heat transfer between the ice and the air. Here we're looking to minimise that heat transfer.
The following users thanked this post: tooki, Kim Christensen
Online Ian.M
« Reply #4 on: January 08, 2024, 12:09:27 pm »
Basic thermodynamics.  The energy required to heat 1 kg of a substance by 1 K (degree Kelvin) is known as its specific heat capacity.   It can (and does) vary with respect to temperature but it wouldn't be a useful concept if the energy required wasn't directly proportional to the mass.
Therefore, with the same heating power, in a perfectly thermally insulated vessel of negligible thermal mass, 1L of water will boil exactly ten times faster than 10L of water.
The only differences are the losses, and as the surface area of a container scales with the square of its linear dimensions and the volume with the cube, it is likely that the larger container will loose less heat boiling 10L than a smaller container will loose boiling 1L ten times.
The case when the container is not of negligible thermal mass is more interesting.  In real life no-one waits for the kettle to fully cool to room temperature  before refilling it to boil it again, so the first time takes longer as the kettle starts from cold, but all subsequent refills boil a little quicker due to stored energy in the kettle.
Offline djsb
« Reply #5 on: January 08, 2024, 12:30:11 pm »
Do the pots mentioned have lids placed on them when filled? Are they being watched? The saying is a watched kettle (or pot) never boils  :)
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Offline mendip_discovery
« Reply #6 on: January 08, 2024, 12:45:12 pm »
10L pot.
Takes the same energy to heat the water. The mass of the pots should be similar.
As soon at a 1ltr pot is up to boiling point you need to swap for the next pot. This takes time.
But this is one of those arguments where you only need to adjust the goal to complicate the problem. Much like this 10 x 3 x 6 + 5 = ? Kind of questions go about the place as somone will adjust the parameters to meet the answer they want.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Online Zero999
  • 0999
« Reply #7 on: January 08, 2024, 01:37:33 pm »
It depends.
If the 1l pots were in a big oven, then they would boil quicker, since they have more surface area to absorb heat from the hotter ambient temperature. If they each had an element and surrounded by room temperature air, then they would boil slower, since more heat would be lost to ambient.
« Reply #8 on: January 08, 2024, 02:21:36 pm »
It depends.
"It depends" seems to be the most correct answer to most questions. :)
I think we all agree the amount of heat the water needs to boil is the same in both cases so the problem boils (!) down to heat gained and lost in the heating process.
To give just one example, say I have an electric hot plate that produces 250 W. It is possible that a 1 L pot will boil in X minutes but a 10 L pot will never boil because it reaches a temperature where it loses more than 250 W through the sides and top.
« Reply #9 on: January 08, 2024, 02:23:36 pm »
We need to specify these are Schrodinger pots which are being watched and not being watched at the same time.  :)
Offline tszaboo
« Reply #10 on: January 08, 2024, 02:50:28 pm »
It takes the same amount of energy to boil the same amount of water, that's obvious.
You are asking the wrong question though.
Why are we boiling the water?
Making tea? Desalination? Disinfection? Making soup? Energy storage/generation?
Most of these questions have a lower energy solutions.
Online themadhippy
« Reply #11 on: January 08, 2024, 03:05:41 pm »
if the pots are the same diameter then the 10 litres,cause 9 litres will be at a higher elevation and reach boiling point at a lower temperature
Offline tunk
  • Country: no
« Reply #12 on: January 08, 2024, 03:13:47 pm »
Or at a higher temperature because the pressure at the bottom is higher.
Online coppice
« Reply #13 on: January 08, 2024, 03:17:11 pm »
What do you mean by boil? Reach 100C or bubble? Nucleation issues (e.g. surface contamination in the pots) will affect when bubbling gets going. If you are just looking to reach 100C, then if the heat is applied within the bulk of the water, that is 100% efficient, and the pots with the greatest losses will boil the slowest. Evaporation is usually a big loss, unless the pots have narrow necks, so probably the pots with the greatest total surface area will suffer the greatest loss, and boil the slowest. In a strong draught, maybe losses from the outside of the pots will dominate, and the pots with the greatest total outside surface area will be the slowest.
Offline IanB
« Reply #14 on: January 08, 2024, 03:30:11 pm »
This is an example of a question that cannot be answered as given, as it will depend on so many unstated assumptions. Each person answering the question may make different assumptions, and so may arrive at as different answer.
The only way to address this question is not to answer it, but to discuss the kinds of assumptions that might need to be made to give an effective answer.
We can give a "spherical cow" answer, by making some very unrealistic assumptions:
1. In both cases we have the same mass of water (10 L = 10 kg)
2. In both cases we are heating the water from the same starting temperature to the same ending temperature (e.g. from 20°C to 100°C).
3. In both cases the rate of heating is identical (e.g. 3 kW)
4. All the heat added goes into the water and none is wasted
5. No heat escapes from the water to the surroundings (perfectly insulated containers)
6. No boiling or evaporation occurs (which will consume additional heat beyond that required for raising the temperature)
By making assumptions such as these, we can observe that the time to bring the 10 kg of water to boiling point will be identical in both cases, since heating water without losses is a path-independent process. To raise a given mass of water from one temperature to another will require the same amount of energy regardless of whether you do it in pieces or as a whole. If the power input is the same in all cases, then the time taken will also be the same.
Now, by varying or relaxing the listed assumptions above, such as by allowing for heat losses, then the answers can change, and this is where the interest may lie.
« Last Edit: January 08, 2024, 03:41:45 pm by IanB »
Offline RoGeorge
« Reply #15 on: January 08, 2024, 03:44:23 pm »
Boiling water FAST!
MOMables - Laura Fuentes
Offline madires
  • A qualified hobbyist ;)
« Reply #16 on: January 08, 2024, 04:03:08 pm »
It boils down to efficiency.
The following users thanked this post: Ian.M, RoGeorge
Online Zero999
  • 0999
« Reply #17 on: January 08, 2024, 06:19:34 pm »
Boiling water FAST!
I use an electric kettle and water from the hot tap, if available. Some people say don't drink water from the hot tap, because it's from a tank and has being sitting there for a long time, but it should already be hot enough to kill bacteria and even if it isn't, you're going to boil it anyway,.
Online coppice
« Reply #18 on: January 08, 2024, 06:22:15 pm »
Most UK homes no longer have an open header tank. In those homes there is no reason not to drink the hot water, even if it hasn't been heated enough to sterilise it.
Offline Smokey
  • Not An Expert
« Reply #19 on: January 08, 2024, 06:31:08 pm »
Offline thm_w
  • Non-expert
« Reply #20 on: January 08, 2024, 10:06:21 pm »
Its an example but not really a realistic one. You can get a 2000W induction hot plate for about $50, or a 2200W kettle for less.
No one should be using a 250W heater unless its just to keep food warm.
« Reply #21 on: January 08, 2024, 10:11:49 pm »
It's called "proof of concept". And the price of hot plates don't enter into it.
BTW, I wonder how much spherical cows are going for these days.
Offline thm_w
  • Non-expert
« Reply #22 on: January 08, 2024, 11:34:45 pm »
Correct term was "thought experiment" as per your original post, proof of concept would mean you are actually testing a product out.
The price and wattage is relevant because you didn't specify anything other than "of the same wattage" in the original post. A typical burner on an electric or gas stove is going to be 1,200-2,200W, so that is what one would expect to use when determining an answer. I think IanB put far more effort into this thought experiment, maybe consider that direction in the future.
Online SiliconWizard
« Reply #23 on: January 08, 2024, 11:39:34 pm »
But can water boil faster than the speed of light?
Offline PlainName
  • Country: va
« Reply #24 on: January 09, 2024, 12:03:56 am »
Warm water from the hot tank contains contaminants (hot water + metal = corrision). Hot water systems fur up where cold water doesn't - worth thinking about.
As for legionnaires disease, the water needs to be at least 55C to kill the bacteria, but that's too hot if you're going to put your hand in it. At 51C it will take 3 mins to scald your hand, at 56C 15secs. There is reliance on the system losing enough temperature at the tap that the tank can be hot enough to kill off stuff, yet you don't scald yourself accidentally. On the plus side, most outlets in a house get used often, so water isn't likely to be sitting in a dead spot while being warm.
