Author Topic: How to bypass GitHub's new 'Enable two-factor authentication'.  (Read 11582 times)
Offline Shonky
Re: How to bypass GitHub's new 'Enable two-factor authentication'.
« Reply #25 on: August 17, 2023, 05:34:50 am »
Are you saying I need to buy some hardware to access GitHub?
I'm beginning to like 'KE5FX's idea except I know I will never get any traffic with some blind web page out there.
No. You could use SMS or an authenticator app (mobile or Windows based) or the Github mobile app. You're well aware of this. Again you're just ignoring reality because you don't like it.
You want "traffic"? For what? You're happy to use the free service provided but not happy to use it as is?
If you create your own web page/server/whatever you can do what you want with it. That seems like your best option at this point.
Offline ejeffrey
« Reply #26 on: August 17, 2023, 06:05:48 am »
No you need a software or hardware second factor not both.
It's really not that hard, it's clearly documented.  It's true the most common path involves using smartphone apps and if that's not an option for you you will have to look a bit closer.  Go read the Wikipedia article on TOTP or the GitHub documentation that is linked above.  All the answers are there and it shouldn't take you more than 10 minutes to set up and is available for essentially every platform in existence.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Online EPAIII
« Reply #28 on: August 17, 2023, 07:32:06 am »
I looked up GitHub. QUOTE,
"GitHub, Inc. is a platform and cloud-based service for software development and version control using Git, allowing developers to store and manage their code."
So if you want to be a developer, you need to put your code, YOUR CREATION on a cloud based service where others can hack into it and steal it?
Welcome to the new world order!
Why can't a developer just store the code on their own computer until it is time to sell it? And then sell it any way they want? Oh, wait! Oh, wait, that would mean that others won't control it and profit from your work. Yep, I think I have it now.
Gotta run and answer that angry knocking at my door - in the middle of the night. I probably won't be back. Bye!
« Last Edit: August 17, 2023, 07:34:40 am by EPAIII »
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Online RoGeorge
« Reply #29 on: August 17, 2023, 07:43:06 am »
The USB security key is just a simple USB device with a touch sensor.   It's the most secure option but requires special hardware.  It's not terribly expensive but it isn't free.
Could self host your files, of course, but if you want some public repository hosting website (without mandatory 2FA), there is GitLab (not GitHub).  GitLab does about the same things as GitHub, it's free for individual users https://about.gitlab.com/pricing/ , and doesn't require 2FA.
Even more, once you'll login into your GitLab account, you can import your project(s) from GitHub into GitLab with a few clicks from the GitLab webpage.  Many users imported their repositories from GitHub to GitLab, and never looked back.  Some also deleted their code from GitHub, others left an unmaintained copy on GitHub, too.
You can try importing your projects into GitLab anyway, whether you get 2FA for GitHub or not, and see if you like it:
https://gitlab.com
« Last Edit: August 17, 2023, 07:53:52 am by RoGeorge »
The following users thanked this post: Karel
Online HwAoRrDk
« Reply #30 on: August 17, 2023, 08:13:26 am »
Hmm... my GitHub account is not linked to a phone number, and I haven't received such an email. I wonder if this is something that's being gradually rolled out to users.
Yes, GitHub are doing a staged roll-out of 2FA to all users throughout 2023.
Offline madires
  • A qualified hobbyist ;)
« Reply #31 on: August 17, 2023, 08:37:56 am »
TOTP suggestions for linux users:
- otpclient (small and nifty TOTP tool)
- keepassxc (PW manager, TOTP hidden in the right-click-menu for entries)
The following users thanked this post: bingo600
Offline PlainName
  • Country: va
« Reply #32 on: August 17, 2023, 08:42:11 am »
You're being completely inflexible just because you don't like something IMO.
Why does one have to like everything? I bet there is stuff you don't like and are happy to whine about given half a chance, and what is wrong with that? If you don't like something it's not a crime to say so, or feel that way.
Offline Shonky
« Reply #33 on: August 17, 2023, 09:07:36 am »
Sure but don't just ignore the other options hence my comment about being inflexible. At first it was "I won't use SMS", then it was "I don't know what TOTP is but haven't tried to look", then it was "I have to pay for a hardware key to use Github?" (obviously paraphrased)
As has been offered if he doesn't like what Github want he's perfectly free to take his business elsewhere.
« Last Edit: August 17, 2023, 09:13:34 am by Shonky »
Online bitwelder
« Reply #34 on: August 17, 2023, 11:30:03 am »
I'd suggest also oathtool for command-line usage.
Online bitwelder
« Reply #35 on: August 17, 2023, 11:35:01 am »
Password managers like Bitwarden can save the TOTP secret as well as have notes for the recovery keys.
Although, one should consider that this way is keeping all secrets in one basket: if the key to open the password manager is not strong enough or not kept safely enough, one would lose at the same time all the passwords AND all the TOTPs. So much for two-factors.
The following users thanked this post: KE5FX
Offline Shonky
« Reply #36 on: August 17, 2023, 11:44:54 am »
Absolutely true it does somewhat make it no longer 2 factor.
You can add 2 factor authentication on unlocking the password store if you wish via email, TOTP and a couple of other methods.
Offline bingo600
« Reply #37 on: August 17, 2023, 04:50:33 pm »
THANX !!  :-+
I just set github OTP w. keepassxc (linux mint)
I didn't even have to use the QR Code , just click on the "Skip" URL , and it'll show you the github TOTP Seed.
"Right click" on your keepassxc github entry, select TOTP , select Setup.
Paste the TOTP seed , let rest be default ... Done
github login
login as usual , user + pass
right click github entry in keepassxc , select TOTP , select Copy TOTP   (Or just hilight the github entry and press CTRL+T)
Paste it in github 2FA "Box"
Edit: You'll find the TOTP (2FA) stuff @github , under "profile -->password"
/Bingo
« Last Edit: August 17, 2023, 05:30:07 pm by bingo600 »
The following users thanked this post: BrianHG
Offline PlainName
  • Country: va
« Reply #38 on: August 17, 2023, 09:42:41 pm »
That's my problem with this stuff - it's a road bump (and not a small one). For most places I just go there and I'm in. If I had to manually log into everything every time I'd go mad with the amount of stuff that would involve, and most 2FA is exactly that kind of pissing about. (And you're stuffed if you're not at your PC because you cannot remember or otherwise access the 2FA key).
If we were talking about access to Microsoft's internals it would be fair enough, but it's our data and if someone nicks it or corrupts it it's our fault and our tears. Not theirs. I agree with the previously stated viewpoint that when it comes to our stuff it should be our choice. We are grown people who know the risks and can deal with them appropriately (and if we can't then it's our tough shit, that's all).
« Last Edit: August 17, 2023, 10:02:31 pm by PlainName »
Online abeyer
« Reply #39 on: August 17, 2023, 09:52:19 pm »
Sometimes I read this forum and just shake my head in regret that I didn't take up haberdashery and buy an industrial scale supply of tin foil.
The following users thanked this post: ajb, newbrain
Offline Halcyon
  • Global Moderator
« Reply #40 on: August 17, 2023, 10:02:08 pm »
As others have said, 2FA is going to be unavoidable with most legitimate providers, and it really shouldn't be feared or resisted.
No, it should be optional.
Why?
It's there to protect you and your account. Cyber attacks are getting increasingly sophisticated and ultimately, people are lazy and use recycled, weak or compromised passwords all the time. Whilst you might use a strong password, doesn't mean that it can't be compromised in a data breach.
People should embrace multifactor authentication as it's here to stay. Its implementation is as difficult as you make it. For me, I use Bitwarden both on my PC and my phone, so I always have my TOTP codes with me, which is tied to my Yubikey that's always in my pocket (or nearby).
« Last Edit: August 17, 2023, 10:04:33 pm by Halcyon »
Offline PlainName
  • Country: va
« Reply #41 on: August 17, 2023, 10:08:01 pm »
Do you log into your PC? I don't mean do you have a password set up, but do you have to manually enter it every time you go to your PC? I recall that one upon a time at least one Linux distro enforced that, but even they succumbed to allowing auto logon.
Now we're in a highly connected world with IoT providers tunnelling on the LAN, how is that really different to the cloud? There's even more risk here since someone could just not hack and physically sit at the machine.
You'll change your mind when you have to do 2FA instead of swiping to access your phone :)
Offline madires
« Reply #42 on: August 17, 2023, 10:10:32 pm »
Unfortunately, not everyone is grown up and is able to assess the risks. So someone tries to help (or force) those experts to follow best current practice. If a widely used library is affected you'll have a nice supply attack wreaking havoc.
Offline Halcyon
  • Global Moderator
« Reply #43 on: August 17, 2023, 10:23:30 pm »
Yes, I login to my PC manually every time I sit down at the chair. It takes 2 seconds. Even when I'm switching between users, I enter the password each time.
As for TOTP codes, even on my phone Bitwarden automatically copies them to clipboard for me when I'm logging into a site/service that requires it. It's extremely simple to use and doesn't require swapping between applications.
Offline PlainName
  • Country: va
« Reply #44 on: August 17, 2023, 11:10:18 pm »
Bitwarden
Great that it works for you. It won't for me because it's online and doesn't support Windows 7. I have no desire to swap my open source existing solution for another more onerous open source solution, just as you no doubt wouldn't want to use some of the stuff that I would rave about.
[And TOTP is a paid option, and even self-hosting requires online license download. Fail to pay, no more bitwarden for you. No thanks - I want secure password store, not reliant on some paid cloud thing.]
« Last Edit: August 17, 2023, 11:22:38 pm by PlainName »
Offline Halcyon
  • Global Moderator
« Reply #45 on: August 17, 2023, 11:19:41 pm »
Bitwarden
My point is, MFA doesn't have to be cumbersome. It's as cumbersome as you make it. I'm not suggesting everyone go out and use Bitwarden (which by the way can be used entirely offline), there are plenty of other solutions out there.
Offline PlainName
  • Country: va
« Reply #46 on: August 17, 2023, 11:23:58 pm »
Yes, there are other solutions. I am using one. But they are still a pain in the arse compared to not having to use them. It should be my choice, that's all.
The following users thanked this post: m12lrpv
Offline Shonky
« Reply #47 on: August 17, 2023, 11:48:27 pm »
Nope, authenticator app is included in the free version
Nope there is no license involved for vaultwarden. Nothing to pay if you self host vaultwarden
It is secure but you don't really care that much about security since you're still on Windows 7 yeah? Saying one solution is more onerous than another is entirely arbitrary particularly if you've clearly not even tried it.
Offline PlainName
  • Country: va
« Reply #48 on: August 18, 2023, 09:26:06 am »
I can only go by what they try  to sell me.
Offline Shonky
« Reply #49 on: August 18, 2023, 09:32:17 am »
Derp. Ok yes you can't store TOTP in Bitwarden for free unless you self host. I was wrong.
The 2 step login is only for unlocking.
« Last Edit: August 18, 2023, 09:38:03 am by Shonky »
