I should have some photos but hopefully you can visualize the situation after the following description. I need to replace a (1996 vintage) 5.7 inch LCD monitor on a CNC control with another make, as the original LCD has ceased to exist anywhere in the NOS market. I have found another 5.7 LCD with near identical specs...except for two issues-
1. The new LCD uses much smaller cable... 18 connector, .5mm spacing flat cable. The original monitor uses 16 connector, round flat ribbon cable, with a two level connector on the end (i.e 8 holes on top, 8 holes below) to connect to the control. (not sure of wire spacing but probably at least 1mm)
2. Although the basic LCD specs are the same, the arrangement of connectors for what spec does what, are different. In other words, the connector for logic power supply on the old monitor is "pin" 5, whereas on the new one it is pin 14.
So, even if by some miracle an appropriate adapter connector existed, I doubt I could use it anyway due to all the wires I have to lap over each other to achieve same functions at the plug end.
(FWIW, I only need 15 of the wires of either cable, so for purposes of this discussion, don't concern yourself with the 18 vs 16 aspect)
Bottom line is the 18 wire, .5mm spacing cable terminals, even under stereo microscope, are just too close together to solder the wires from the old cable to. So all I can figure to do, is cut out an inch or so of each of the 18 wires with Exacto razor under microscope and then seperate each wire enough to solder appropriate wires from the old ribbon cable. Then to insulate, create a potting compound around the width of the ribbon cables at the joints.
Even with Hakko 936 iron and some experience in soldering tiny components, I'll bet it will be difficult as hell to actually do it however. Therefore wondering if anyone else had a better idea ? For example, I suppose a custom PCB could be created that would utilize one of the many 18 wire .5mm connector possiblities and expand the connections out via traces to solder eyelets for the old cable. But how on earth are those .5mm flat cable connectors actually soldered to a PCB in the first place ? Seems like it would be beyond human capabilites, and have to be an automated situation....but you tell me ?
