To return this to the original question, if you have sufficient number of capacitors of a particular type to test to destruction, apply a current limited DC voltage to a representative sample of the lot, increasing the voltage until the dielectric ruptures, calculating the max, min, mean and standard deviation.
Apply a reasonable safety factor to the result, perhaps 3:1 or 4:1 from the mean.
That strategy won't be useful if you have 5 or 10 parts of each particular type, but if you have 100 or 200, sacrificing 5 or 10 for a destructive breakdown test isn't too bad a price to pay.
With a knowledge of a reasonable maximum recommended operating voltage, you can then look at C versus V over the rated voltage to get an idea of the dielectric class. NP0/C0G ceramic will have next to no change in capacitance with applied voltage. X7R will have a lot and Z5U even more. (I assume these are ceramic capacitors.)
If you want, I'll can run a destructive test on a few parts for you - at least up to 1KV, don't think I can easily go beyond that point without kludging up a HV transformer and a Variac and I don't have time for that. But, I can run up to 1 KV with a standard lab HV supply. Contact me directly if you are interested. I can't run hundreds of different parts, but be glad to look at a dozen or so samples of four or five different values and/or capacitor types.
With respect to surface mount ceramic caps, most every C0G/NP0 part I purchase is light gray color whilst the X7R types are brown or tan. That's not universal and I don't suggest it as a definitive test for dielectric class, but I can say that I've never seen a light gray ceramic surface mount cap that was not a C0G/NP0 type and that I've never seen an X7R of light gray color. I have seen a few C0G/NP0 parts that are brownish, particularly in values of a 100 pF or less.
