Author Topic: how to extend laptop waranty for free  (Read 1679 times)
Offline strawberryTopic starter
  • Country: lv
« on: November 28, 2022, 11:26:01 am »
Offline PlainName
  • Country: va
Re: how to extend laptop waranty for free
« Reply #1 on: November 28, 2022, 12:30:01 pm »
Can you just condense 20 mins of video into 10 words of text to give an idea of what it's about? Like "Bloke uses thermal foam to cool stuff" or similar?
The following users thanked this post: mcovington
  • Country: lv
« Reply #2 on: November 28, 2022, 04:28:32 pm »
DIY upgrade original thermal performance by transfer heat from heat hot spots to larger surface area for better cooling and component longevity
I add copper tape and pads to cool smartphone CPU PMIC (at boot up CPU gets hot ~100C) when original heat pad and PCB gets loose a bit, CPU die
The following users thanked this post: PlainName
Offline tooki
« Reply #3 on: November 28, 2022, 04:58:11 pm »
https://youtu.be/biKeXepP8hw
Clickbait title on this thread. A warranty is a legal thing (a promise of function for a period of time), and cooling a device does NOTHING to change the warranty.
The following users thanked this post: Zero999, hans, NiHaoMike, tom66, Fraser, amyk, Someone, ealex, edavid, EPAIII, Ian.M, newbrain, Ranayna, james_s, Nominal Animal
Online Zero999
  • 0999
« Reply #4 on: November 28, 2022, 06:18:20 pm »
Thanks. Now I know not to bother clicking on it.
To be fair to the original poster, perhaps it was a mistranslation and he thought warranty meant life expectancy?
  • Country: lv
« Reply #5 on: November 28, 2022, 07:59:12 pm »
not the best title indeed , I guess he is youtube addict or something
Offline hans
Re: how to void your laptop waranty for free (-:
« Reply #6 on: November 28, 2022, 08:21:37 pm »
Placing thermal pads all over the insides of a device may sound like a "fix" but in reality it's just bandages on a sprain. You can put heatpads on MOSFETs and chipsets etc. but what if those devices were very robust and did not account to any realistic future failure anyway? The CPU/GPU sees a far more higher thermal stress which can crack solder joints..
Moreover, if you make a device externally too hot, then you wish it was better isolated for bursty loads or the fan to move the air out.  You don't need a full 55C+ heat source to burn you: https://antiscald.com/index.php?route=information/information&information_id=15
So putting those pads on a M2 drive and chipset may keep them cold, but if they burn your leg at just 48C in 15min, then that's bad.
The following users thanked this post: wraper
  • Country: lv
« Reply #7 on: November 28, 2022, 08:55:16 pm »
bond wire failure due to high temp stress above ~+55C
at high temp atom migration in silicon can lead to transistor property change (at high clock rates more errors and crashes)
resale value of newer devices seems lower
4y old laptop starts failing charger and battery (~1200EUR when brad new)
Online thm_w
  • Non-expert
« Reply #8 on: November 28, 2022, 10:04:38 pm »
You can use the embedded link:
I mean it might help with caps dying prematurely I guess? Slightly easier than recapping. But then you don't even know if they will fail.
Online wraper
  • Country: lv
« Reply #9 on: November 28, 2022, 10:09:57 pm »
What a junk. Randomly sticking thermal pads like this won't help dissipating the heat to any significant amount. If anything they probably make the airflow worse.
Offline tooki
« Reply #10 on: November 28, 2022, 11:39:31 pm »
Actually, I take that back: doing this modification probably WILL change your warranty, by voiding the warranty due to an unauthorized modification. But it most certainly won’t extend it…
The following users thanked this post: tom66, Someone
Offline Halcyon
  • Global Moderator
« Reply #11 on: November 29, 2022, 12:58:34 am »
For those living in Australia and saw the title of this thread, but couldn't be bothered watching the video, I just want to touch on your legislated consumer guarantees (known as Australian Consumer Law), which are independent of any manufacturer's or store warranty. I've banged on about it before, but a lot of people still don't fully understand what rights they have as consumers. This advice is applicable to Australia only, but is regardless whether or not the company selling the goods/services are Australian.
The long version is here: https://www.accc.gov.au/consumers/buying-products-and-services/consumer-rights-and-guarantees
The even longer version is here: http://classic.austlii.edu.au/au/legis/cth/consol_act/caca2010265/sch2.html
Basically in a nutshell, if a product is deemed to have experienced a major failure or is not of "acceptable quality", then you are eligible for a full refund or replacement, regardless whether the original manufacturer's warranty is still intact or not.
Obviously there are several moving parts and specific definitions which need to be taken into account, such as the definition of a "major failure" (see S.260 of the act). For example, if you tamper with a product and break it, you aren't covered (it's not your job to rectify a manufacturing or design fault). Likewise if the product is cheap (say a $20 toaster) and it fails after 2 years, then the argument can be made that given the price/quality/construction of the product, it is reasonable for it to only last that long.
Apple is a good example of a company that has been smacked several times for breaching ACL. In many cases, paying extra for extended warranties doesn't give you any more protection that is already afforded to you, for free, by law. Always read the fine print.
It's a complex topic and one that could be discussed for days, however, just because a product is out of warranty, it doesn't necessarily mean the manufacturer or the seller get out of remedying a faulty item. The car industry is another that has been trying to get away with it for years, citing manufacturer warranty terms and conditions. That being said, if you don't follow the service schedule on your car, then you're out on your own (and no, you don't need to take your car to the dealer to have it serviced, any qualified mechanic can perform servicing for you and it doesn't impact your vehicle's warranty status).
The following users thanked this post: tooki, Nominal Animal
Offline John B
« Reply #12 on: November 29, 2022, 01:15:47 am »
There's also the conundrum of whether or not you should actually financially support companies making bad products by fixing them. Like those dangerous soldering irons and hot air tools from china. I'm not totally opposed to the idea.... if it's sold as a factory reject at like a >90% discount  ;D
The following users thanked this post: NiHaoMike, tooki
Offline EPAIII
« Reply #13 on: November 30, 2022, 09:33:09 am »
"The major enemy of electronics is the heat."
WOW, we have a major discovery here. I never would have thought of that! Why haven't the designers of electronic devices known that? And incorporated cooling into their designs?
This man is a genius.
And what's with the gloves? Is he afraid of shocks from 5 or 10 Volts? I worked in electronics for over 45 years and never wore a glove. I guess I was just lucky to survive.
That's ten minutes I'll never get back.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
