Author Topic: How to locate an underwater object with a compass?  (Read 1201 times)
Offline ChrissTopic starter
« on: August 20, 2020, 02:22:23 pm »
Hi!
Do somebkdy have any suggestion how can I locate the gps coordinates of an object in the water with a compass?
These objects are close to each other. Something like from 30cm to 2.5m.
From tools I have only a compass.
Thanks.
Online Ian.M
Re: How to locate an underwater object with a compass?
« Reply #1 on: August 20, 2020, 03:10:19 pm »
With  a *really* good magnetic hand-bearing compass, up-to-date charts and a detailed survey of any local magnetic anomalies, you could triangulate off three well spread out, distinctly visible landmarks at accurately known latitude and longitude coordinates to get a position on the surface at best accurate to approx. +/-10 meters per Km of distance from the landmarks.   You'd do better with DGPS in the boat which could reduce the surface position uncertainty by an order of magnitude or two.  Transferring that position to the seabed in anything except shallow water is problematic due to currents and tides.  In a still lake you *MIGHT* be able to maintain reasonable accuracy dropping a plumb-line.
The pros will be using something like a network of DGPS equipped sonar buoys or a towed hydrophone array with surface GPS transponders  at its head and tail.
« Last Edit: August 20, 2020, 03:12:30 pm by Ian.M »
The following users thanked this post: Chriss
« Reply #2 on: August 20, 2020, 04:32:04 pm »
These object are in a river, around 3-6m deep.
Some wood pillars which circle are 70cm.
I shoukd as a diver go down and locate them and if any
possibility to record the coordinates.
The visibility is really poor, aroind 30cm.
Online 2N3055
  • Country: hr
« Reply #3 on: August 20, 2020, 04:35:50 pm »
How do you expect to detect wooden (nonmagnetic) object with a compass that works on magnetic principle.... :-//
Dr. Richard W. Hamming
Offline NivagSwerdna
« Reply #4 on: August 20, 2020, 04:38:58 pm »
tape measure... actually two tape measures
anchor end of each at known different point... and then measure distance to each to point to be measured
plot result from triangulations
doesn't sound like a fun job in that viz
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #5 on: August 20, 2020, 06:25:01 pm »
compass is useless for wood you require sonar or echo beacon . ultra sound would also work at close distance .
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
Online tggzzz
« Reply #6 on: August 20, 2020, 10:53:32 pm »
Hi!
Thanks.
Find somebody who knows where the object is, and say "if you tell me where it is, I will give you this compass".
The following users thanked this post: HackedFridgeMagnet, Ian.M, NivagSwerdna, 2N3055, george.b
Offline cdev
« Reply #7 on: August 21, 2020, 02:41:07 am »
Have a bunch of boueys that can seve the GPS locaion and attach to a bouey\\and a rope and an sold achor
