In Windows Explorer you can add a column for Bit rate(Audio) / Data rate (video) / Frame Height+Width / Horizontal or Vertical Resolution - which you can then order by, multi-select, and delete.
In the folder / search results change the view type to "Details" then right-click on the column headings and select which extra columns to display.
