Author Topic: How to reproduce symbols on a knob?  (Read 1266 times)
Offline bitwelderTopic starter
« on: July 03, 2021, 03:23:09 pm »
Hello,
I have a issue that while not strictly about electronics,
perhaps some hobbyists that build or repair devices with knobs may have faced.
I would like to replace the knob used for the oven of my cooker.
I bought an 'universal knob' which fits and works well but... it's plain white.
How to properly reproduce the symbols from the original knob to the replacement one?
Both are white molded plastic (with black drawings).
My ability to hold a black pen and draw it manually is definitely not up to scratch  ;D
I was thinking of taking photos of the symbols and printing them on a sticky transparent tape,
but then, would it resist to heat, as it's near to a hot oven?
Any suggestions?
Reason for this change is that my cooker has some almost cylindrical knobs.
While those are easy to operate for the induction plates (after all they are potentiometers
or maybe rotary encoders) the one for the oven is rather stiff and clunky,
and the smooth knob surface is hard to grip with a hand that is even a little greasy or wet.
The replacement part instead has a more sculpted profile that makes it easy to grip in any circumstance.
Offline Ian.M
Re: How to reproduce symbols on a knob?
« Reply #1 on: July 03, 2021, 03:45:08 pm »
My first inclination would be to take it to a trophy engraving shop that does plastics, have them engrave it then carefully fill the symbols with a fine tipped paint marker of your chosen color.
The following users thanked this post: bitwelder
Offline geggi1
« Reply #2 on: July 08, 2021, 09:21:30 pm »
if its only letters or numbers the simplest way is to use a lablemaker like a Dymo.
Just print the caracter and tape it in place.
If you want it engraved you can use a fine tip on a dremmel and carefully grind the caracter in to the knob.
If you want colour in the caracter dont remove the dymo tape yet, but add paint on top of where the caracter and let the paint dry before removint the tape.
Clear varnish can be added on top to et a smoot surface.
« Reply #3 on: July 10, 2021, 06:13:23 am »
Well no, as the title of the post, the knob has unusual symbols (like 'oven grill', 'top and bottom heating', etc.) not text,
but actually a label maker is an interesting idea:
1) as my own oven doesn't have to be used by many people in different languages :D,
I could think of replacing some of the simpler symbols with a descriptive word.
2) I am actually in a search for a new affordable label maker (currently I own a really annoying Dymo Letratag),
maybe I can find one that allows also to program some custom symbols.
Offline ChuckDarwin
  • Country: gu
« Reply #4 on: July 10, 2021, 09:11:13 pm »
Might be an expensive solution, but laser printable waterslide decal material and some acrylic overcoat would allow you to design whatever symbols ring you want, assuming a light background.
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
« Reply #5 on: July 11, 2021, 12:24:57 pm »
Yes...  Something like using a laser printer to make PCB transfers, like in the following video.
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
