The problem with connecting Al and Cu is that these have a serious
electrode potential difference. It is 0.6V in between those. Take a glass of electrolyte (H2O with dissolved CO2 would do), dip separated copper + aluminum wired to voltmeter and you have a 0.6V electrochemical cell. Stack in series and you can charge an iPhone. However, your customers won't be happy as this reaction is irreversible and would eat up an anode (aluminum harness).
So, you have several choices to prevent that:
1. either you can keep wires in electrolyte as long as you like but do not connect both electrically. I admit this trick may not be practical with electrical harness..
2. or you can connect Al+Cu safely but do not allow the electrolyte to get involved in between them.
3. or you can separate metals with something that has an intermediate electrode potential. A 0.1V difference would slow the process to a safe level.
4. or make the electrolyte path long enough to discourage serious current to flow there ,
5. or you can use a sacrificial anode (give an electrolyte something tastier than Al harness)
6. or apply a constant >0.6V in reverse (which is similar to trick #5)
7. etc
Anyway, usually the cheapest is to do trick #1 if you do not need electrical connection or #2 if that electrical flow is necessary.
You can buy
sheets that are made of two/three layers of adequate electrode potentials that are cold rolled together. No electrolyte can get in between. Mind that sheet works only in standard conditions (humidity) so won't help much if flooded in electrolyte because it still has Al+Cu edges. Also won't work if you flip the sides so it is a quality control problem.
