Hi all,
I need to test a variety of power supply circuits at home and I am considering purchasing a bench-size programmable electronic load. Typical power supplies might exceed 300VDC at a few mA. On the other hand some low voltage supplies are in the 1.8-48VDC range at a few amps. Overall, I dont have an immediate need for anything above 150W. I will be needing a constant power and constant current modes, with constant resistance being useful (depending on response time).
There are a few China-made candidates on ebay and rebrands of those. However, keeping all options open, what other specifications would you be looking at when searching for an electronic load? I wont be doing any testing of PV panels, so I cant see the minimum input voltage as a function of current being a high priority factor. Budget is about $500.
Any input/ideas much appreciated.
