Author Topic: How to trigger a combined signal  (Read 3263 times)
Online RAPoTopic starter
« on: October 12, 2022, 06:56:33 pm »
Recently I acquired a 3-channel isolating amplifier switch.
Basically it generates from 3 signals a new wave signal, where the first signal
rides on the top of the wave, the second signal is in the middle and the third signal rides on the bottom.
See the attached images.
The question is: how can one best trigger such a combined signal?
The apparatus has a selectable trigger-out signal, but that achieves triggering of the input signal, not the combined signal.
« Last Edit: October 12, 2022, 06:58:57 pm by RAPo »
Offline EPAIII
Re: How to trigger a combined signal
« Reply #1 on: October 13, 2022, 03:49:35 am »
I have used oscilloscopes for over 56 years. I have never seen anything like that. What is the purpose/use of such a thing? Your "3-channel isolating amplifier switch" seems to have three Voltage steps and each of your input signals is SWITCHED on during and superimposed upon one of these three levels. It appears to be a type of combined time and Voltage level multiplexing. But WHY? WHY would you want to do that? ?????????????????????????????????????? Or, if that is not what it is doing, then WHAT?
As for triggering, you do not give enough information to allow an answer. I see several possibilities:
1. You have access to all three of the initial signals, which appear to be phase locked together as well as the combined signal from your "3-channel isolating amplifier switch" which also appears to be phase locked to the input(s). In that case, I would simply choose one of the input signals, the triangle waveform seems like a good choice, and use that for your trigger signal. But this ASSUMES that the input signals are what you show and not something else (like stereo audio and composit video, perhaps or maybe R, G, B video or whatever).
2. Your input signals are not always what you show (sine, triangle, and ???) but can be any arbitrary waveforms including random noise. In that case, you need to look to your "3-channel isolating amplifier switch" for the possibility of a trigger signal. Perhaps as a separate output. Or you may need to modify it's circuitry to bring out such a trigger signal. (Side question: How is the frequency of the three steps generated? From one of the input waves? Which one? From some combination of all three? How are they combined? More questions along this line.)
3. Your input signals are not available and you do not have a trigger from the "3-channel isolating amplifier switch" and you can not modify it's circuitry to obtain one so you must trigger from that mess of a combined waveform. In that case and if your input signals do not change over time, then PERHAPS a low frequency filter or band pass filter can produce a trigger signal. I have been in similar situations and getting a good trigger was NOT EASY.
4. Oh heck, there are just too many more possibilities to keep going through all of them. Perhaps you can be more SPECIFIC.
But I have heard that things will be different, things will be BETTER when we have digital oscilloscopes.
Oh, wait, wait ... we DO have digital oscilloscopes. So, what's the next iteration? Analog, digital, then _____! And when do we get IT?
I can't wait.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Offline EPAIII
« Reply #2 on: October 13, 2022, 04:10:29 am »
OK, upon rereading I see another interpretation here. You ask, "how can one best trigger such a combined signal?" Does this mean what it says? Are you looking for a trigger that PRODUCES the input signals in some other apparatus? Is that how they are generated in a phased locked condition with the three steps of the "3-channel isolating amplifier switch"?
But you seem to have those signals already. I see them on the scope's display.
And if it IS triggering the generation of the input signals, then why can't be also used to trigger ----- but here I do not know what to say because your words, once again, seem not to make sense.
You say, "The apparatus has a selectable trigger-out signal, but that achieves triggering of the input signal, not the combined signal." By that do you mean that it triggers the beginning of the steps in your "3-channel isolating amplifier switch"? That is what it seems to say. But that would be obvious. Something must trigger those steps. Or do you mean that it is a trigger that is available to use on a scope to view the combined signal? But, in that case, aren't your photos showing scope waveforms that are properly triggered on/in the scope?
What exactly are you trying to trigger? The input waveforms? The step waveform in the "3-channel isolating amplifier switch"? The scope display? But all of them seem to be nicely triggered in your photos. So WHAT?
And in what piece of equipment do you wish to trigger that? In the "3-channel isolating amplifier switch"? In the waveform generator that generates the inputs? In a scope? In some other piece of equipment? Be specific please.
Frankly your photos seem to show that everything IS being well triggered! So I really must ask.
...<snip>...
Paul A.  -   SE Texas
Offline jonpaul
    • IEEE Spectrum
« Reply #3 on: October 13, 2022, 04:59:28 am »
schematic or block diagram no idea what you are doing
j
An Internet Dinosaur...
« Reply #4 on: October 13, 2022, 07:23:10 am »
The apparatus is just in. I'm exploring it now. As for the why, it seems to do two things: a poor man's extension to an oscilloscope in order to get more channels. I've seen an article where there were 4 inputs calling it a quad tracer. In that article, the channels were not isolated, in this apparatus it is. The second thing seems to be the isolation amplifier part (https://www.google.com/search?q=isolation+aplifier+switch) but I haven't done any tests on that.
The phase locking is in reality not necessarily there, I just showed some easily recognizable signals.
Indeed it is meant to work with different input signals (different waveforms, different amplitudes, different frequencies, and different phases).
As described the apparatus has a switch 'Trig-out' where you can select one of the input signals, the BNC-out connector shows the corresponding original signal. However, that doesn't trigger the yellow combined signal.
More on that later, but my question is: if you only have the yellow signal how can you achieve a stable signal on a (digital) oscilloscope. I can set a trigger on the overall signal that shows the yellow signal more or less triggered but not the different signals in the respective regions. It all looks like it is triggered because it is a screenshot, in reality, there is no locking in the regions even if I use the same frequencies.
Good questions on how the yellow signal is generated. I'm still exploring don't know yet.
As described I have the separate signals available, but I would like to work only with the yellow signal. I have seen video's on how to trigger an oscilloscope if you have two separate signals with different frequencies. That indeed is not easy. This case is different, I have one signal with three regions, and just putting an edge trigger with a trigger level in one of the regions does not give a stable image.
I'll try to give answers to your posts.
« Last Edit: October 13, 2022, 07:53:37 am by RAPo »
« Reply #5 on: October 13, 2022, 07:36:00 am »
I'm not looking for a trigger to produce signals. I'm looking for guidelines howto set up a trigger on the yellow combined signal that gives a stable image on the digital oscilloscope.
For E.g. is it better to use an edge/pulse or window trigger? Where should the trigger level(s) be set. Just some guidelines to get in the ball park.
See the earlier post, just assume you have only the yellow combined signal with three different regions where each region has a different signal. What is the best way to trigger such a yellow signal.
How to setup a trigger of the yellow signal on a digital oscilloscope, not assuming any of the underlying signals, such that the display is as stable as possible and you still see some information on the three signal bands.
It looks like that because it is a screenshot and the signals have roughly the same frequency and because I just by trial and error got a nice picture. The yellow signal e.g. can jump up/down when setting an edge trigger with a level between the 3 regions.
« Reply #6 on: October 13, 2022, 07:39:50 am »
j
I haven't found any details on this apparatus. In the attached image you'll see the front end, the inner parts and another experiment.
« Reply #7 on: October 13, 2022, 07:48:24 am »
The quad tracer I mentioned has the following schematic.
« Reply #8 on: October 13, 2022, 05:52:09 pm »
I think I am getting to answer my own question.
Step 1: arrange signal heights so there is a space to set an edge trigger with a level, not in the signal regions. This stabilizes the overall image.
Step 2:The apparatus has a pot, with it you can arrange a chop_freq (between 6.5kHz and 23.8kHz).
Try (the pot is very sensitive) to get the chop frequency such that it divides the frequency of one of the input signals.
The chop_frequency is not a constant
Step 3: Put an holdoff slightly larger than 1/chop_freq.
See https://www.flickr.com/photos/renseposthumus/52425634949/in/photostream/
Online nctnico
« Reply #9 on: October 13, 2022, 05:59:10 pm »
Such a scope channel extender won't work for a dso because a dso can't display several traces simultaneously like a cro can (at least optically)
« Last Edit: October 13, 2022, 06:00:51 pm by nctnico »
The following users thanked this post: tom66
« Reply #10 on: October 13, 2022, 06:04:48 pm »
Did you see the video with the Rigol mso104? The crux is that the apparatus converts the 3 input signal into *one* output signal. So only one trace that embodies the input signals in its upper/middle/lower part.
Offline Alex Eisenhut
  • Place text here.
« Reply #11 on: October 14, 2022, 01:33:04 pm »
Is this supposed to be like "chop" mode on a CRT scope? It's usually only used for low frequency (whatever that may mean for a particular model). The scope just switches as fast as possible between inputs and puts the beam on the screen!
It triggers on whatever you want before the chop circuit AFAIK.
« Reply #12 on: October 14, 2022, 02:02:05 pm »
Yes it works in a similar way as far as I can tell.
No. If I look at the triggered output BNC, it shows (depending on the switch settings) the one-off original signals, the composite signal (the yellow trace) is not triggered even if I use the trig-out signal as an external trigger.
Online tom66
« Reply #13 on: October 14, 2022, 03:41:19 pm »
The only way you could get a circuit like this to work is to have the scope sweeping fast enough that in the modes that use intensity grading the traces overlap.  Generally that occurs once the timebase is much below one whole display frame (assuming the screen refreshes at 60Hz and 12 div horizontally, that starts to happen below 1ms/div)
However note that such modes give relatively poor performance for measurement functions etc and single shot modes will show one of the 3 different traces.
Really this does not work well with digital scopes due to how digital phosphor modes work, they behave only superficially like an analog scope does.
You still need to find some way to trigger the scope to the tracer's pulse output and you would not be able to trigger on the actual waves themselves, a quick think about how digital oscilloscopes manage pre and post trigger times will make that clear pretty quickly.
What you want to buy is an analog capture card of some kind, they often capture 16+ channels at one at low frequencies.  You cannot do what you want for any reasonable real world application with a DSO.   Sorry.
The following users thanked this post: RAPo
« Reply #14 on: October 14, 2022, 04:09:20 pm »
On an analogue scope, it is indeed easier.
« Reply #15 on: October 14, 2022, 04:22:26 pm »
Yes I discovered that just a moment ago (are you telepathic ;)
Not necessarily because there is only one trace. If the frequencies are near each other of an exact multiple of a specific frequency, it gets easier.
indeed but trying this out on a digital scope triggered (pun intended) a nice dicovery/learning process.
On an analogue scope using an external trigger tied the trigout-BNC of the apparatus triggers on the selected input signal. Of course the other signals start to roll.
Sorry is not needed, many thanks from my side is. I have no real application for this apparatus, it was an impulse buy from the local craigslist thinking: that looks like an interesting device, lets try it.
For 65 euro's one can have a lot of fun.
« Reply #16 on: October 14, 2022, 08:59:59 pm »
One normally starts an exercise like this by learning about the many and various trigger types a DSO has over a CRO and how to use them.
Another useful trigger tool is Holdoff however one must first decide where on a complex waveform one wants/needs to trigger and then apply the trigger type and Holdoff if required to get the result needed.
« Reply #17 on: October 15, 2022, 07:11:53 am »
Life throws things sometimes in a different order.
I already had some scopes then this apparatus came and then one wants to find out how the heck it works.
indeed:
Offline StillTrying
  • Country: Broken Britain
« Reply #18 on: October 16, 2022, 01:32:12 pm »
If you want to trigger separately on 3 or 4 channels there's no way to do that, there's no analogue ALT like option. All the sampling and displaying timing is locked to the one trigger channel so you can't stabilize different frequency inputs.
You'd have to look a single shots?
Triggering on the yellow conbined is not much use because its switching frequency isn't related to the analoge input frequency(s).
You might be able to make 1 DSO channel look a bit like 3 inputs by using persistance and dots mode?
https://www.batronix.com/files/Rigol/Oszilloskope/MSO5000/MSO5000_UserGuide_EN-V2.0.pdf
« Reply #19 on: October 16, 2022, 01:45:18 pm »
I'm trying to trigger on 1 channel (the yellow one), not  3 channels
That goes for a *digital* scope, the analogue scope can (within bounds) trig on the yellow signal and one of the 3 input signals, see images.
yes, will try that.
Offline tooki
« Reply #20 on: October 16, 2022, 02:26:15 pm »
Can you link to the original magazine in question instead of a poorly-cropped low-resolution screenshot in which nothing can possibly be read? I can make out that it’s Popular Electronics, so it’s almost certainly available for us on worldradioarchive.
« Reply #21 on: October 16, 2022, 02:31:49 pm »
Here it is: https://worldradiohistory.com/Archive-Poptronics/90s/92/PE-1991-07.pdf
Offline StillTrying
« Reply #22 on: October 16, 2022, 02:45:13 pm »
"I'm trying to trigger on 1 channel (the yellow one),"
It should be possible to get some sort of temporary stable trigger on that yellow because Signal 3 always shoots up to Signal 1 giving a long +ve edge.
Perhaps move the trigger level away from the middle Signal 2 level, trigger on AC coupled, or add "Noise Rejection" to the trigger, can't think of much else. :)
« Last Edit: October 16, 2022, 02:47:06 pm by StillTrying »
« Reply #23 on: October 16, 2022, 02:51:40 pm »
I arranged the things such that there is no overshoot from the signals in the 3 regions. What you see are the chop lines.
Offline tooki
« Reply #24 on: October 16, 2022, 02:57:09 pm »
j
It’s on page 63 of the catalog here: https://www.yumpu.com/en/document/view/5663030/electrical-machines-elwe-lehrsysteme . (Use the login from http://bugmenot.com/view/yumpu.com if you want to download the PDF.)
The manufacturer went out of business and was bought up years ago by a company called LD Didactic, which is still around. They may be able to supply the manual. (They have a downloadable archive of manuals, but requires registration to download.)
