Author Topic: How to write  (Read 1569 times)
Offline PerranOakTopic starter
How to write
« on: April 30, 2020, 03:58:50 pm »
I often wish to write on plastic or metal, e.g. PCB, cable/connector, etc. - or even glass.
However, normal felt pens will not do it the ink just wipes off even when “dry”.
Does anyone know of a pen (fine nib, not fat like a Sharpie) that will do this?
Cheers.
You can release yourself but the only way to go is down!
RJD
Online themadhippy
Re: How to write
« Reply #1 on: April 30, 2020, 04:17:43 pm »
fine tip sharpie?
Offline oPossum
Re: How to write
« Reply #2 on: April 30, 2020, 04:36:54 pm »
Online Ian.M
Re: How to write
« Reply #3 on: April 30, 2020, 04:41:15 pm »
Even so-called permanent markers like Sharpies aren't persistent on smooth metal surfaces, glass and glazed or vitrified ceramics, and waxy plastics and dependent on the carrier solvent may not be persistent on smooth epoxy surfaces e.g. PCBs. They typically smudge or wipe off with skin contact during normal handling.   For a permanent result, you are likely to have to prepare the surface by abrading, etching or flame treating it it, then use a paint pen or preferably a pigment ink with a themo-curable binder compatible with the substrate, and seal it with a coat of lacquer.
Online Twoflower
Re: How to write
« Reply #4 on: April 30, 2020, 04:49:40 pm »
How about paint markers like Edding 780 or similar ones.
Online wraper
  • Country: lv
Re: How to write
« Reply #5 on: April 30, 2020, 04:52:38 pm »
You can bake it though at something like 200oC. And then it will be pain in the ass to remove even with strong solvent.
Online Alex Eisenhut
  • Place text here.
Re: How to write
« Reply #6 on: April 30, 2020, 05:30:11 pm »
What's your budget?
 8)
Offline aargee
Re: How to write
« Reply #7 on: May 01, 2020, 07:07:29 am »
Those fine tip 'white-out' pens do a fairly good job.
Not easy, not hard, just need to be incentivised.
Offline EEVblog
Re: How to write
« Reply #8 on: May 01, 2020, 07:13:40 am »
You can get really fine point Sharpies / permanant markers.
Offline Wendy_Preston
  • Content Marketing Specialist for Harwin
    • Harwin.com
Re: How to write
« Reply #9 on: May 01, 2020, 07:31:10 am »
Content Marketing and website technical content for Harwin (ex Design Engineer) - contact me on webmaster@harwin.co.uk.
Re: How to write
« Reply #10 on: May 01, 2020, 10:39:01 am »
That's brill, thanks all - I'll look into those ideas.
RJD
Offline Gyro
Re: How to write
« Reply #11 on: May 01, 2020, 06:28:34 pm »
The Edding 8404 Aerospace marker works well, nice and fine. It's a bit prone to drying out though.
https://www.edding.com/products/edding-8404-aerospace-marker/
« Last Edit: May 01, 2020, 06:32:15 pm by Gyro »
Best Regards, Chris
Offline james_s
Re: How to write
« Reply #12 on: May 01, 2020, 09:13:31 pm »
I use one of those little label printer things, I think mine is made by Brother, I got it for a few dollars from a thrift store. The tape cartridges are expensive but you get quite a few labels out of one. They're a lot tidier than hand written labels, at least a lot tidier than *my* handwritten labels.
Offline CatalinaWOW
Re: How to write
« Reply #13 on: May 01, 2020, 09:26:34 pm »
An old school option is a drafting pen with appropriate ink.  Plain old India ink is OK, not great on many of these surfaces.  I don't recall brand names but there are grippier inks available.
