Author Topic: How would you use electronics to solve the 11' 8" bridge problem  (Read 15708 times)
Online tooki
Re: How would you use electronics to solve the 11' 8" bridge problem
« Reply #100 on: January 09, 2018, 07:28:41 pm »
I think some here mentioned options are more expensive than just digging the road a little deeper like the water curtains, those are probably very expensive and do only get used when the tunnel is built and not 10m long but 100m.
My idea would be to completely limit passthrough for trucks altogether even for smaller once so that wouldn't be any more a problem. Another solution might be the steel pipe option like mentioned earlier its a very cheap and effective option gets used in Europe (Italy) a lot for tunnels and bridges.
As soon as you start aiming for electronic solutions you may start digging because most electronic solutions will be more expensive than just a sign limiting passthrough or lowering the road.
You think the water curtain is more expensive than digging up the road for blocks to lower the sewer lines?!?  :-DD
Offline floobydust
« Reply #101 on: January 09, 2018, 07:39:05 pm »
Self-driving cars would probably screw up here as well.
No they won't. If the map says they won't fit. They won't drive there.
Where is this map you speak of that knows all bridge/overpass heights? I only know of GPS maps containing altitude data.
Offline Gyro
« Reply #102 on: January 09, 2018, 08:09:05 pm »
Kudos to the brave and sturdy steel beam that is doing an AWESOME job protecting that bridge from insane truck driving skills all day and night! :clap: :clap: :clap: :-+
That beam should have been shaped and sharpened like a blade.  This way, the trucks could go through smoothly without noticing a thing...  :-DD
I agree. If you watch the video, most of the trucks lifted significantly at the front end as the beam dug into the rear. That could cause a damaging impact with the underside of the bridge.
They should be aiming for a nice clean cut to reduce truck lifting, protect the driver from too sudden deceleration, and probably minimize the damage from distortion too.
It would probably minimize road closures too, as the truck would probably make it out of the other side. There might need to be some sort of guide to safely roll up the 'shavings' though!  :-DD
Chris
"Victor Meldrew, the Crimson Avenger!"
The following users thanked this post: BrianHG
Offline xygor
« Reply #103 on: January 09, 2018, 08:11:17 pm »
Forgive me if any of theses have already been mentioned.
1. Lower the crash bar.  Make it break-away, but make it *look* substantial.  And/or narrow the width of the entrance.  Make it evident that the driver is entering a confined space.
2. A very high ramp that drops off just before the bridge.
3. Rumble strips.  And/or rumble strips with audio encoded.
4. An outdoor advertising sign showing an animation of the actual vehicle crashing and displaying the license plate.
« Last Edit: January 09, 2018, 08:12:50 pm by xygor »
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #104 on: January 09, 2018, 08:20:23 pm »
Professional GPS assistance systems have this. You will setup your truck specifications (or better the dispatcher will do so), when uploading the tour/route information. However, these systems are expensive and a lot of smartypants are using home entertainment style GPS devices to save money. Professional systems also give tracking data back to the dispatcher and have two way communication over mobile network. That way, the route can be updated remotely in case of time schedule changes or because of traffic.
He’s like a trained ape. Without the training.
Offline Gyro
« Reply #105 on: January 09, 2018, 08:28:14 pm »
Yes, we have problems with that in the UK too, Heavy lorries getting jammed between houses scenic little villages because the drivers are using cheap 'car' GPSs. Occasionally they have to be craned out. There are lots of 'Unsuitable for... GPS divert' type of signs these days.  It's not just bridges that suffer.
Chris
Offline floobydust
« Reply #106 on: January 09, 2018, 08:37:55 pm »
You can't simply lower the road, because that is part of the rail bridge's support.  It would result in redesigning the rail bridge, its concrete foundations at least would have to be replaced. And, how long a trailer do you design for? You'd  have to lower the road quite far out on either side.
I'd be curious what the damaged vehicle and bridge repair costs are over the years, the insurance payouts.
I think this bridge problem is just nobody wanting to spend the money and fix it.
Online Someone
« Reply #107 on: January 09, 2018, 08:51:09 pm »
Such maps exist in the heavy vehicle industry but they are expensive, we can assume that with the high volumes expected of autonomous cars they can afford to include such detailed data for their own use.
Offline james_s
« Reply #108 on: January 09, 2018, 09:39:39 pm »
Personally I expect fully autonomous cars are about 20 years behind where most of the enthusiastic backers think they are. It's true that Google has driven thousands and thousands of miles, but this is mostly over the same few miles of extremely well documented routes. The days of computers doing a sensible job of interacting with human drivers and the unexpected is still a long way off. Look at how difficult it is for a computer to positively identify spam email, something an average human can do at a glance with probably better than 99% success rate. Google in particular has gotten pretty good at this but still gets false positives or lets spam through to my inbox occasionally and that task is orders of magnitude simpler than driving a car. I'm not saying it won't happen, but there will be kinks to work out, both expected and likely some completely unforeseen. I suspect that enthusiasm and hubris will lead to a rushed deployment and there will be several highly publicized incidents in which a number of people are killed and that will be a setback. Time will tell.
Offline Mr. Scram
  • Display aficionado
« Reply #109 on: January 09, 2018, 09:45:42 pm »
You're basically describing the hype cycle. I suspect legislation will dampen that, though other interests like achieving environmental goals might reduce caution in governmental agencies.
Offline jmelson
« Reply #110 on: January 09, 2018, 11:18:54 pm »
Yes, this has a lot of potential!  How about making it a pinata!  Make it out of thin-wall PVC drain pipe, and fill it with sand and gravel, and anchor it well enough so it will break when hit.  Then, the truck is showered with a big deluge of sand and gravel when hit.  That ought to make the driver notice "something" is wrong.
If done right, it might be really easy to reset for the next case.
Jon
Offline jmelson
« Reply #111 on: January 09, 2018, 11:22:23 pm »
I suspect most commercial vehicle insurance policies only cover liability in cases like this.  If you drive your truck into a bridge, the losses to the vehicle are likely NOT COVERED!
Not only that, if you do it more than a couple times per company, you won't be able to get insurance.
Oh yeah, there was the famous case where a guy with a flatbed truck loaded with a HUGE excavator went under a too-low overpass in Hays, Kansas.  The arm on the excavator punched up through the overpass and twisted the excavator around 180 degrees.  It twisted the beams in the overpass to the buckling point.  The highway patrol didn't stop traffic in both directions until a structural engineer looked at it and had a FIT!  The driver apparently went to jail for a few months, lost his CDL and the company was fined some two million dollars for the damage.
Plus, the truck and excavator were totalled.  I'll bet their insurance company was not thrilled.
Jon
« Last Edit: January 09, 2018, 11:28:41 pm by jmelson »
Offline Mr. Scram
« Reply #112 on: January 09, 2018, 11:27:07 pm »
I suspect most commercial vehicle insurance policies only cover liability.  If you drive your truck into a bridge, the losses to the vehicle are likely NOT COVERED!
Jon
[/quote]
Apparently, this kind of damage is usually specifically excluded. That makes for some very sour grapes.
Offline james_s
« Reply #113 on: January 09, 2018, 11:28:43 pm »
The commercial truck that rear ended me last year was self-insured by the trucking company. I don't know how common that is but I suspect it's fairly typical for major trucking companies.
Offline Zero999
  • 0999
« Reply #114 on: January 10, 2018, 11:01:13 am »
I agree about the hype and before self-driving cars are widespread, the technology will have to be more widely applied to simpler applications, such as trains and trams.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #115 on: January 10, 2018, 11:44:32 am »
Trains have been automated for decades. ???
Go figure that a graph of one-dimensional paths is an easier solved problem. :)
Seven Transistor Labs, LLC
Offline Zero999
  • 0999
« Reply #116 on: January 10, 2018, 02:01:31 pm »
Where? There are a few driverless trains in the UK but most still have drivers. I can't speak for everywhere else. Perhaps the UK is more conservative with safety critical technology than elsewhere.
Offline T3sl4co1l
« Reply #117 on: January 10, 2018, 02:03:59 pm »
AFAIK, the primary duty of an "engineer" is tapping the watchdog button every minute or so.
I don't know to what extent the actual driving is automated (at the throttle and brake), but route planning, certainly.
Offline IanB
« Reply #118 on: January 10, 2018, 02:16:52 pm »
[/quote]
As you may know the DLR has been fully driverless from the start.
On the London Underground several lines are now running with Automatic Train Operation (meaning the trains automatically regulate their speed and obey signals without manual intervention). The driver's duties mainly involve controlling the doors and monitoring passengers at stations.
I can see something similar happening with automatically driven cars. In the USA today there are isolated HOV lanes (express lanes for vehicles with more than one passenger) on many freeways. One could imagine in future that these lanes might be reserved only for automatic vehicles. Upon entering the lane the manual controls are disconnected and the car drives itself automatically maintaining a fixed distance from the cars in front and behind. All of the cars in the express lane could end up moving like a virtual train with no bunching, no sharp braking, and no waves of stationary vehicles.
Offline Zero999
  • 0999
« Reply #119 on: January 10, 2018, 02:51:52 pm »
It didn't stop the most recent huge accident on the west coast, which I believe was due to human error, which wouldn't have happened, if it were fully automated.
That's a relatively small proportion of the rail network.
We also have guided busways which aren't fully automated. If they were, then it's possible some of the recent accidents, due to driver error (excess speed) could have been avoided. Once the bus is on the guided bussway, the only controls the driver should have access to are the clutch and break, in case something goes wrong.
Perhaps one day, but is unlikely to happen in the near future.
My point is, there are already plenty of jobs which technology is already mature enough to do, yet they've not been filled by it, even though it would be safer and cheaper, in the long term. No doubt one day there will be driverless cars, but the technology isn't quite there yet and even when it is, it will take a while before it's implemented.
Offline W2NAP
« Reply #120 on: January 10, 2018, 03:14:14 pm »
its called the truckers atlas https://www.amazon.com/McNally-Deluxe-Motor-Carriers-Mcnally/dp/0528017578
lists overpasses that are less then 13' 8" that are on state roads/us highways (ie truck routes)
Offline W2NAP
« Reply #121 on: January 10, 2018, 03:15:33 pm »
typical of mega carriers like swift,werner who hires right from trucking school newbs
Offline james_s
« Reply #122 on: January 10, 2018, 04:48:38 pm »
Imagine the pileup when a wheel comes off a truck in the adjacent lane or some other debris ends up in the automated lane and the cars slam on their brakes. I'm sure there will be some spectacular failures, especially early on.
Offline james_s
« Reply #123 on: January 10, 2018, 04:52:59 pm »
This was a Kenan Advantage gasoline tanker. I don't know what the driver was doing but he wasn't paying attention. He slammed into the car behind me at ~50 MPH while we were stopped in a backup at the exit. Long straight section of freeway, I saw him coming a long way away in my rearview mirror, assumed he would slow down and stop.
« Reply #124 on: January 10, 2018, 06:14:57 pm »
Years ago in the 1980's my father did a study ( he was a fleet manager for a region) and convinced the top to change the insurance they used. Insure the main hauler, insure the trailer, insure the driver, have full third party insurance, riot and political unrest and full public liability insurance, but not to insure the load. His reasoning was that, as the insurance rate for the freight alone was around 5% of total value, yet the claims amount was 3%, that self insurance was the cheaper option, and actually was a much cheaper option as well, because the amount that the breakages was could then be claimed back from the Receiver, as most of the value of the breakages cost was Excise Duty, seeing as the trucks were delivering beer alone.
Seeing as the major part of making a unit of beer is actually various taxes, duties and such Ad Valorum and the actual cost of making, bottling and distribution are smaller, then the claim back actually was cheaper. As well the losses were controlled better, simply by changing the packaging to a shrink wrapped pallet that could be handled in bulk with a fork lift, and putting extra trolleys on the trailers in a dedicated bay for delivery, saving carrying cases one by one, instead taking 11 at a time. Spec all trailers to have air suspension as well, and the losses dropped down to only in major accidents.
