Author Topic: Howto date LEDS  (Read 13492 times)
Online RAPoTopic starter
Howto date LEDS
« on: March 30, 2024, 03:45:22 pm »
I have a set of (red-) LEDs, no ID numbers.
Is there any way to date these leds?
2089691-0
« Last Edit: March 30, 2024, 03:49:11 pm by RAPo »
Offline Gyro
Re: Howto date LEDS
« Reply #1 on: March 30, 2024, 09:00:50 pm »
That's odd (assuming that they're both Red). Early dim Red GaAsP LEDs had a much lower dynamic resistance than modern high brightness types, those started in the '70s though. If comparing the two, I might have put the plots the other way round. The higher voltage one looks very noisy, likely to be defective / reject.
It's hard to tell anything from the plots, you might learn more from looking at the dies.
Best Regards, Chris
Online SiliconWizard
Re: Howto date LEDS
« Reply #2 on: March 30, 2024, 10:20:09 pm »
Dating LEDs from their I-V characteristics is an ... interesting approach.
The following users thanked this post: wraper, schmitt trigger
Offline schmitt trigger
  • Country: mx
Re: Howto date LEDS
« Reply #3 on: March 31, 2024, 04:46:56 am »
Perhaps the OP would care to elaborate his theory.
« Last Edit: March 31, 2024, 04:48:38 am by schmitt trigger »
Re: Howto date LEDS
« Reply #4 on: March 31, 2024, 09:23:43 am »
yes indeed, but I double checked the connections/screenshots.
The 19YY LED looks like a desoldered one, maybe that's what we see here.
Re: Howto date LEDS
« Reply #5 on: March 31, 2024, 09:24:34 am »
It was one of those brainwaves I sometimes have ;-)
Re: Howto date LEDS
« Reply #6 on: March 31, 2024, 09:42:19 am »
Well, the theory is simple (but maybe practice is not).
An I-V graph of an LED shows where the voltage drop remains constant independent of the current.
For example, a red LED has a different voltage drop than a blue one because they are made of different materials.
In the run of the years, different materials were also used for a red LED.
The earliest LEDS had a semiconducting alloy gallium phosphide arsenide (GaAsP); nowadays, the red LEDs are made of Aluminum indium gallium phosphide (AlInGaP).
These different materials should show up as different I-V diagrams.
If there was a table indicating period->used material->voltage drop, we could measure the voltage drop and then work backwards to get an (approximate) time of manufacturing.
Offline Gyro
Re: Howto date LEDS
« Reply #7 on: March 31, 2024, 01:02:37 pm »
For a long time, you could buy standard LEDs, high brightness LEDs, superbright LEDs, ultrabright LEDs etc. There was a huge overlap.
Best Regards, Chris
The following users thanked this post: RAPo
Offline BrokenYugo
Re: Howto date LEDS
« Reply #8 on: March 31, 2024, 01:57:41 pm »
IIRC milspec 1970s style LEDs in the hermetic metal can package are still in limited production and available. Huge overlap indeed.
Re: Howto date LEDS
« Reply #9 on: March 31, 2024, 02:25:24 pm »
There goes my theory.
Offline Gyro
Re: Howto date LEDS
« Reply #10 on: March 31, 2024, 05:46:02 pm »
Old Red GaAsP LEDs are worth keeping around for low voltage bias supply 'Zener' use. In measurements taken by Morgan Jones for his Valve Amplifiers book, he found that these LEDs (forward biassed) have a dynamic resistance of around 4.3R @ 10mA, compared to 6R for a 1N1418 1N4148 - and of course you would need three in series to achieve the same voltage (18R). True low voltage Zeners fare very badly in comparison, LEDs are much quieter too.
« Last Edit: April 01, 2024, 12:16:01 pm by Gyro »
Best Regards, Chris
The following users thanked this post: tooki, RAPo
Re: Howto date LEDS
« Reply #11 on: April 01, 2024, 12:37:31 am »
I see the idea, but I'm curious about what you're going to get in practice. Obviously, the first step will be to get ahold of batches of LEDs from various periods and do some stats.
Re: Howto date LEDS
« Reply #12 on: April 02, 2024, 04:55:44 pm »
You could try hanging out in the same light-bars, choose one at the same wavelength as yourself, and put your best voltage forward
The following users thanked this post: schmitt trigger, Wallace Gasiewicz, RAPo
