In our multimeter scenario the speed of response is everything, how many half cycles of fault current will the components of the device sustain before something gives way explosively. We are talking a hand held device here.
One of my meters is 10A continuous rated, but can measure 20A for 30s. I'm sure it could take 50A in a surge without damage. I certainly wouldn't want to replace my fuse due to a half cycle of 20.01A going through my meter!
HRC fuses are generally slower to blow than glass fuses at low fault currents. Take the Cooper Bussman DMM-B 11A fuse that is used in some Fluke meters (a fast-acting HRC). At 1s, it's taking approx 7I to blow. Compare to a Schurter FSF-5 glass fuse (just a random selection), which at 1s has blown at 3I. Then go to 0.1s - the HRC fuse is at 10I, and then at 7I.
This is the fuse that Fluke specify, and it costs over 20 times more than the glass fuse. It blows more slowly from 2I to 10I.
If, and only if, you end up in a situation where the current is greater than 10I, will the HRC fuse blow quicker. Putting 100A+ through a meter at mains voltage isn't an everyday occurrence. I'd say most meter fuses are blown at much lower currents
The same is true for the Littelfuse FLU fuses, HRC fuses designed specifically for multimeters.
So, you have said:
* The fuses on meters must be quick to blow to protect the meter
* The quicker the better, as that is everything in protecting the meter
So, by extension, the HRC fuses specified by the manufacturers would be some of the fastest available if this were the case? So why aren't they? Why can I find quicker glass fuses?
The bulk of ? Now that is somewhat different from your prior statement that my reference to fast action simply saw not true! It appears the goal post are being shifted now. And then we add terms "standard electrical supplier" and "commonly available types" we were after discussing the application of a specialist fuse and its use in a specialist device! HRC fuses by application will seldom be a retail commodity. A great many of the HRC fuses used particularly those used around semiconductors will be fast acting.
You stopped referring to HRC fuses in meters specifically a long time ago and started making general comments about HRC fuses.
No it doesn't make the case that HRC fuses are slower by design. There is considerable effort placed into the design characteristics of the fusible element in terms of it's dimensions, material selection and tolerance. That sliver of wire in a good HRC is not the same random chunk of nichrome you'll find in hardware store glass fuses. And yes that careful design is applied and yes it's another contributor to the comparatively higher prices of HRC fuses.
A lorry is slower by design than a car. Put a huge engine, nitrous, and modify the gearbox in a lorry and it can beat most cars. But it's taken a lot of extra effort, and it still doesn't go round corners as well.
It's very difficult to make a HRC fuse quick, mainly due to the additional effort required to heat the fuse element. This is as a result of their design. You've pretty much backed up what I'm saying here.
Glass tube fuses aren't a random chunk of nichrome at all - take a look at some with a magnifying glass and you will see blobs and crimps to tune the response, coils to pull apart the fuse etc.
Risks due to fuse replacement? Why not have all our fuses replaced with nails then or spent rifle cartridges, that'll be much safer, for sure.
You deny that there is a risk involved with replacing fuses? Even in a multimeter, there are risks. What happens if the replacement is incorrect?
