To "tekfan", 'yes' I did select CH2 as the trigger source
To "Balaur", hello and thank you for the reply.
Unfortunately, yes the trigger level was/is correct.
My software if 7.0.0.3, so that is probably not the problem.
So, if yours is working correctly, it is not a design flaw, so I presume mine is faulty
Thank you all.
