If the car is diesel, the best thing is to use the lowest sulphur fuel in it at all times. that reduces the NOx and SOx emissions which combine with the ambient air to make a dilute Aqua Regia solution in the garage. As well simply putting a blower to always pull air from outside into the garage ( that way you can filter the dust out of it as well so less cleaning) from high up will help a lot.
How much space you are given? My approach would be to environment controlled just the space I needed and not the entire garage. There are ready-made plastic-transparent-curtain compartment available but I do not know is this available at your place. Or you could make one, and put in the lighting, dehumidifier and suction as you see fit. Other not environmental sensitive items could be put outside that compartment.
