That being said, I wonder how much my calibration is off (if at all). They were calibrated at about 30 metres ASL, I'm at 800+ metres ASL.
For a "normal" scale, the error of +800m will not be detected.
At +800m you get around 0.01% deviation from your calibrated value.
A 1.0 gram weight would theoretically show 0.999748 gram at +800m
But the
Buoyancy effect is much larger than I had thought.
For instance:
Steel has a density of 7850 kg/m3
A 2 kg weight 2*1000/7850 = 0.254777 liter of volume
1 m3 air is about 1.3 kg
1 liter of air is therefore 0.0013 kg
0.25 liter of air is 0.254*1.3/1000 = 0.0003302 kg = 0.3302 gram
Therefore a 2 kg weight is about 0.3302 gram heavier in vacuum
This is a difference of 0.0001651 or 0.01651 % or 165 ppm
And it surprised me that it is so much.
