Author Topic: I can't solve a simple equation. Help please.  (Read 1918 times)
Offline intabitsTopic starter
« on: February 02, 2021, 12:40:53 pm »
I haven't routinely juggled algebraic expressions since school over 45 years ago. I do occasionally find myself needing to do so again, and usually with success, but this time I'm stumped.
My program's calculation brings me to point where I'm trying to calculate a value from two others already known, and the equation boils down to something of the form:-
a = (1/x) - 1/(x+b)         (1)
I can't solve this (seemingly simple) equation for x.
a & b are not constants, they're calculated in preceding steps. Since the equation (1) has only one unknown, I expect that there must be some solution of the form:-
x = f(a,b)   i.e. some function of a & b
Then my program (dealing with resistors in parallel and series) can plug in a & b to get a value for x, and continue on its merry way.
But I cannot reduce the two occurrences of x in eqn(1) to just one. I seem only able to make it worse, such as:-
x+b = ax(x+b) + x               with four occurrences of x.
Can someone please provide me with the right hand side of:-
x = ?
(Or explain why it is not possible)
Thanks in advance!
Offline mawyatt
Re: I can't solve a simple equation. Help please.
« Reply #1 on: February 02, 2021, 01:01:56 pm »
Classic quadric equation of x^2 + bx - b/a.
Best,
~Wyatt Labs by Mike~
Offline Spike101
  • Country: at
Offline dmills
« Reply #3 on: February 02, 2021, 01:07:25 pm »
Multiply by (x+b)
a(x+b) = (x+b)/x - (x+b)/(x+b) = x/x + b/x - (x+b)/(x+b) = 1+b/x  - 1 = b/x
Multiply by x
ax(x+b) = b
subtract b
ax^2 + abx -b = 0
Divide thru by a.
x^2 + bx - b/a
Solve as a quadratic by the usual means (Note there are two roots, and values of a and b that will result in x being complex).
Someone check my working, I may have screwed up a sign somewhere or something, it has been a while.
Offline rf-messkopf
  • Mario H.
    • Homepage
« Reply #4 on: February 02, 2021, 01:07:40 pm »
Correct. More precisely, rearranging yields the equation x^2 + bx - b/a = 0. This has two solutions:
\[x_{1,2}=-\frac b2\pm\sqrt{\frac{b^2}{4}+\frac ba}.\]
« Last Edit: February 02, 2021, 01:12:15 pm by rf-messkopf »
« Reply #5 on: February 02, 2021, 07:40:12 pm »
Thanks to all who replied.
Yes, I did manage to get to
ax^2 + axb - b = 0
So I knew it was a quadratic, though I didn't think to divide by a to get
x^2 + bx - b/a = 0
My usual method was to then try to factorize it into something like
(x - 1/a)(x + b) = 0       (incorrect)
and then find the roots by seeing when each of the two factors becomes zero.
I know that's not always possible, and that the quadratic formula was a method to handle that situation.
But although we were taught it, I can't ever recall actually using it!
So I didn't, hoping there was some simpler method.
Though that is (now) obviously the method to use.
I'll blunder on from that basis, and see if I can get the result I'm after.
@rf-messkopf Now I'm now more interested in how your notation works. When I look at the quote of your post, it contains
But that previews just as is, without rendering into the maths notation.
How does that work?
*Update*
Ah ha, it works when you actually post it!
Offline SilverSolder
Offline Terry Bites
« Reply #7 on: February 05, 2021, 01:47:05 pm »
Just because its my birthday....
MS mathematics- Handy, free, works... https://math.microsoft.com/en
The following users thanked this post: Someone, faraday, intabits
Offline CJay
« Reply #8 on: February 05, 2021, 03:24:15 pm »
Oh nice, even better the app, you can take pics of handwritten stuff and it'll try to solve
Offline Nominal Animal
« Reply #9 on: February 05, 2021, 06:11:09 pm »
wxMaxima (GUI) or Maxima (text only) is also an option:
    solve(a = (1/x) - 1/(x+b), x);
                 2  2                           2  2
           sqrt(a  b  + 4 a b) + a b      sqrt(a  b  + 4 a b) - a b
    [x = - -------------------------, x = -------------------------]
                      2 a                            2 a
Maxima is free, and available for Windows, Mac OS X, Linux (in standard package repositories for each distribution), and FreeBSD via FreshPorts.  I suggest installing the graphical version, wxMaxima, though.  Documentation is available here in various forms.
If you are writing a program, then setting display2d to false can be nice:
    display2d: false $
    [x = -(sqrt(a^2*b^2+4*a*b)+a*b)/(2*a), x = (sqrt(a^2*b^2+4*a*b)-a*b)/(2*a)]
« Reply #10 on: February 05, 2021, 07:01:14 pm »
Just because its my birthday.... (Attachment Link)
This is actually rather good - a no BS application!  Remember those?
To download the last standalone desktop application:
https://www.microsoft.com/en-us/download/details.aspx?id=15702
You can say "No" to installing the ancient version of DirectX, with no ill effects
Offline vad
« Reply #11 on: February 05, 2021, 07:11:40 pm »
Another vote for Maxima / wxMaxima.
Offline rstofer
« Reply #12 on: February 06, 2021, 12:29:17 am »
You can plug the equation in at www.symbolab.com, get both solutions.
« Last Edit: February 06, 2021, 01:06:33 am by rstofer »
Offline IanB
« Reply #13 on: February 06, 2021, 01:14:57 am »
ax^2 + axb - b = 0
x^2 + bx - b/a = 0
Here is the way to do it if you can't remember the quadratic formula.
Start with the reduced quadratic:
x² + bx - b/a = 0
Now construct a similar equation that is easier to solve:
(x + b/2)² = 0
If we multiply this out, we get:
x² + bx + b²/4 = 0
We can make this similar equation the same as the equation we want like this:
x² + bx + b²/4 − b²/4 − b/a = x² + bx − b/a = 0
But now we are in a position to solve the original equation:
(x² + bx + b²/4) − b²/4 − b/a = (x + b/2)² − b²/4 − b/a = 0
We have:
(x + b/2)² = b²/4 + b/a
x + b/2 = ± √(b²/4 + b/a)
Therefore:
x = − b/2 ± √(b^2/4 + b/a)
This is the same answer as already presented above, and this method (called "completing the square") is how the quadratic formula is originally obtained.
The following users thanked this post: intabits
« Reply #14 on: February 12, 2021, 01:42:55 pm »
Thanks for the explanation. "completing the square" is a familiar term, but I'd long forgotten what it involved.
