You've included "AMC3330.lib" twice, once as a library from the ModelFile attribute of the symbol and the other explicitly on your schematic as
.inc AMC3330.lib - remove one and that error goes away.
However once that's fixed it throws (in the SPICE Error Log):
Fatal Error: Undefined subcircuit: stdopamp
which is because there is no model for stdopamp in AMC3330.lib, which is written for T.I's TinaTI simulator.
The only useful reference I could find googling
Tina-TI stdopampwas on Stackexchange, and from it I dug out this model:
* STANDARD OPERATIONAL AMPLIFIER MACROMODEL SUBCIRCUIT
* CREATED USING 08/05/06
* (REV 1.53 03/05/16, simplified 1.5, VDROPOL referenced to VP )
.SUBCKT STDOPAMP INP INM VP VM OUT
+ PARAMS: GAIN=200K RIN=2MEG RINC=1E9 CIN=1p CINC=1p ROUT=75 SLEWRATE=500K FPOLE1=5
+ VDROPOH=1.9 VDROPOL=1.9
*FPOLE2=1MEG
.PARAM PI = 3.141592
.PARAM IS = 1.0E-12
.PARAM VT = 0.02585
.PARAM IMAX = 100.0E-2
.PARAM C1 = {IMAX/SLEWRATE}
.PARAM R1 = {1/(2*PI*C1*FPOLE1)}
.PARAM GM1 = {GAIN/R1}
*.PARAM R2 = 100
*.PARAM G2 = {1/R2}
.PARAM GOUT = {1/ROUT}
*.PARAM C2 = {1/(2*PI*R2*FPOLE2)}
.PARAM VDF = {VT*LOG(1 + IMAX/IS)}
RINM1 INM VP {2*RINC}
RINM2 INM VM {2*RINC}
RINP1 INP VP {2*RINC}
RINP2 INP VM {2*RINC}
RIN INM INP {RIN}
CINM1 INM VM {CINC}
CINP1 INP VM {CINC}
CIN INM INP {CIN}
*EVP VPI 0 VALUE = { V(VP)-(VDROPOH + VDF) }
EVM VMI 0 VALUE = { Limit(V(VP)-(VDROPOL - VDF), V(VM) + VDF, V(VP) + VDF) }
EVP VPI 0 VALUE = { Limit(V(VP)-(VDROPOH + VDF), V(VM) + VDF, V(VP)) }
GIQ VP VM VALUE = {5M*ABS(V(P1,OUT))}
GMO2 VM OUT P1 VM {0.5*GOUT}
RO2 OUT VM {2*ROUT}
GMO1 OUT VP VP P1 {0.5*GOUT}
RO1 VP OUT {2*ROUT}
*C2 P2 GND {C2}
*R2 P2 GND {R2}
*GM2 GND P2 P1 GND {G2}
EGND GND 0 POLY(2) (VP,0) (VM,0) 0 .5 .5
D3 VMI P1 D_1
D2 P1 VPI D_1
C1 P1 GND {C1}
R1 P1 GND {R1}
*GM1 GND P1 VALUE = { LIMIT( GM1*V(INP,INM), -IMAX, IMAX) }
GM1 GND P1 VALUE = { IF (TIME < 1e-30, GM1*V(INP,INM), LIMIT( GM1*V(INP,INM), -IMAX, IMAX)) }
*GM1 GND P1 VALUE = { Limit( V(VP,VM)/(Abs(-VDROPOH + VDROPOL)+1m), 0, 1 )*IF (TIME < 1e-30, GM1*V(INP,INM), LIMIT( GM1*V(INP,INM), -IMAX, IMAX)) }
.MODEL D_1 D( IS={IS} XTI=0 EG=0.8)
.ENDS
Adding that model gets us a step further but it still isn't fixed. I then get:
u1:amp:input:c3: both pins shorted together -- ignoring.
Fatal Error: Voltage source E:U1:HLDO:U1:GND is shorted making an over-defined
circuit matrix...
You will need to correct the circuit or add some series resistance.
which I believe *may* be due to the topology of your circuit round the AMC3330. As I hate reverse engineering large models in netlist format to readable schematics, I am disinclined to investigate further.
Maybe use the Tina-TI simulator the model was designed for?
