Author Topic: Inkjet Printed Thermite  (Read 1014 times)
Offline BravoVTopic starter
  • +++ ATH1
« on: January 09, 2018, 08:12:31 am »
After watching this, the 1st thing pop out in my mind is about tight controlled spot metal joining/welding or even soldering maybe ?  :-//
https://youtu.be/8QNQRhBstRg
Offline IanMacdonald
    • IWR Consultancy
Re: Inkjet Printed Thermite
« Reply #1 on: January 09, 2018, 09:30:17 am »
Would possibly have applications for self destruct in military electronics like IFF boxes. Instead of blowing up the whole unit, more selectively destroy the chips containing the data, with less operator hazard.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: January 09, 2018, 09:55:55 am »
Of course once you have the thermite slurry you could just screen print it.
Struggling to think of applications for this - maybe a lower-end substitute for exploding bolts?
Day Job: Mostly LEDs
  • +++ ATH1
« Reply #3 on: January 09, 2018, 11:29:25 am »
Apart from destructive uses like above example, here another one, print close to a spark gap, and if an enough energy and arcing happened across the gap, it will ignite the "ink" and instantly acts as a welder to weld to metal surfaces.
Sort of automatic sealing two metal joints, say for security purpose as the thermite burning temperature can meld metals.
Problem is not sure where or what situation needs this.  :-DD
