No worries, Ex, it sounds like you have both! Most excellent. Time saving features are great in production, but for lab design clean signals are best. If you have a Rigol or any scope with an FFT, push sine wave from the BK to the FFT and it should show a single peak in voltage mode throughout the frequency band. Any other peaks are harmonic distortions. The Rigol can only resolve to about -50dB, IIRC, but the BK specs suggests it has harmonics in the 30-40dB range. they might be visible.
On the Instek, its clean to the limits of the Rigol 1052e I own.
If you have a high stability frequency counter, you can check the drift of any signal, I have an B&K counter accurate to 4ppm, and the output of the Instek is solid to the limits of the counter.
The Instek is very easy to learn to use, I never considered that. The manual is very well made, but there's hardly anything in there you can't figure out, except maybe the limits of the adjustments ... something you can play with to find out.
If I wish for one thing on the Instek, the keyboard I prefer laid out like a telephone keyboard. Its laid out in a straight line in 2 rows. There is so much space to move about on the faceplate they could have easily done that without sacrificing any controls or jacks!
Its suprising similar to this no-name Quakko brand, but the Quakko has features of the model just above this Instek, the one with the voltmeter built in; I wonder if they are from the same ODM, and Instek just rebranded it. Similar price, ~ $150.
http://www.mastechpowersupply.com/function-generator/3-mhz-dds-function-signal-generator-sfg-2003/prod_54.htmlSuper sized photo with details:
http://imagehost.vendio.com/preview/ev/evan2002/SFG2003a.jpgThis is embarrassing.
I meant to say that the BK generator didn't seem to be doing that well for a square wave - I thought it was poor quality. However, I don't have a BNC to BNC patch cable, so I had to cobble something together, and I messed up the ground connection. When I fixed that the waveform looked good.
The Instek may be a bit better, but I was having a difficult time comparing them.
The BK has a sweep function, but the Instek is easier to use. I haven't had to look at the Instek manual at all - the user interface is intuitive. If I can change the "adjusted digit" on the BK, I can't figure out how.
