Author Topic: I learned a lot today...  (Read 11550 times)
duskglow
  • Guest
« on: June 25, 2013, 12:51:09 am »
I learned that I have lead free solder.
I learned that my solder is too thick for a 0.5mm QFP.
I learned that it's really easy to short a QFP with lead free solder.
I learned that lead free solder doesn't melt easily.
I learned that I need a higher quality tip for my soldering gun.
I learned that I wasted about $9 and probably ruined a chip.
I learned that positioning a QFP chip is nearly impossible.
... I learned that I still have a lot to learn.  :(
But at least I fixed my oscilloscope probe's ground with a bit of solder and heat shrink tubing.  There's that.
Offline c4757p
  • adieu
Re: I learned a lot today...
« Reply #1 on: June 25, 2013, 12:52:50 am »
QFP? Nah... fine tweezers, magnification, and no caffeine in the past six hours. You can do it :-+
Offline PeterG
« Reply #2 on: June 25, 2013, 12:55:42 am »
SIX hours without caffeine? Is that even possible?  :o :o
Regards
Testing one two three...
duskglow
  • Guest
« Reply #3 on: June 25, 2013, 12:56:17 am »
I'm going to Fry's to get some thinner 60/40 solder and some higher quality tips, and I'm hoping that that will seal the deal.  I did learn that I can gently hold the QFP in place with some vice grips long enough to get the solder on the leads.
And I do't do caffeine at all, I'm high strung enough without it. :)
Offline c4757p
  • adieu
« Reply #4 on: June 25, 2013, 12:58:04 am »
I say I've been "without caffeine for X hours" when it's been X hours since my last full pot of coffee. Individual cups don't count.  ;)
Offline lgbeno
« Reply #5 on: June 25, 2013, 01:27:28 am »
Solder gun?  Hopefully it's a iron that you hold like a pencil...
Best bet for hand soldering QFN is to put a large via in the center heatslug then you can solder the pads first and fill in the via from the bottom side.  Leaded solder is better but lead free is doable using this method.
Offline c4757p
  • adieu
« Reply #6 on: June 25, 2013, 01:28:13 am »
QFN, or QFP?
Offline nanofrog
« Reply #7 on: June 25, 2013, 03:09:05 am »
I wish it were that simple for me... Caffeine or not, my hands always shake.  |O
Offline c4757p
  • adieu
« Reply #8 on: June 25, 2013, 03:14:14 am »
Mine do too, but I can usually find at least one position to rest them in that makes it minimal. Put a lot of pressure on the table with the rest of your hand.
duskglow
  • Guest
« Reply #9 on: June 25, 2013, 03:54:28 am »
OK, I had fine tweezers, magnification, very fine solder, a very fine solder tip... and for some reason, I can't seem to not bridge the little legs. :(  And then the wick is utterly useless at unbridging them, so I have to pull it off, carefully yank the solder out, recenter it... and promptly bridge them again!  Sigh.
Offline c4757p
  • adieu
« Reply #10 on: June 25, 2013, 04:19:31 am »
There's a word that appears to be woefully missing in this whole thread:
FLUX
Drown the pins in it.
And the wick too, if it doesn't have any. (That's an easy one. Wick with flux: Smells good when you heat it. Wick without flux: Makes you want to kill yourself.)
« Last Edit: June 25, 2013, 04:22:09 am by c4757p »
Offline IanB
« Reply #11 on: June 25, 2013, 04:24:42 am »
You don't use braid to remove solder bridges. Braid is for desoldering parts or for cleaning up pads on the board.
To remove bridges just apply a little flux to the work and touch the clean tip of the iron against the excess solder. The iron tip will suck up the solder like magic.
Watch some soldering videos like the ones from Pace or Hakko for good advice and guidance.
duskglow
  • Guest
« Reply #12 on: June 25, 2013, 04:25:29 am »
I wonder if I have a bad tip.  It's not sucking up solder, the solder's balling up on it.  I can't even tin it.
Offline IanB
« Reply #13 on: June 25, 2013, 04:26:29 am »
Then it's not a bad tip. It's a crap tip. What kind is it?
Was it tinned when new?
duskglow
  • Guest
« Reply #14 on: June 25, 2013, 04:28:26 am »
It's the kind that came with my rework station.  I was already thinking I should get some genuine hakko, now I REALLY think that.
It wasn't tinned, it was just solid metal, whatever the metal was.
Offline Bored@Work
« Reply #15 on: June 25, 2013, 04:42:48 am »
Is that even legal?
And kids remember, flux is no substitute for coffee.
duskglow
  • Guest
« Reply #16 on: June 25, 2013, 07:27:47 am »
Whew, I got it, finally.  After maybe ruining a couple of chips.  I fluxxed the hell out of it (that helped, thanks), learned that a very little bit of solder will go a long way, bumped the temperature 50C, and figured out that even if the wick won't remove the solder bridges, a solder sucker will.  Think I ruined a few rather expensive chips, but it was a good learning experience, so I suppose it was worth it... guess I should order a few more.  I'll do it again tomorrow with another QFP board, just to make sure I got it right.  I think I may be able to salvage the other chips, but sigh.
Thanks for letting me vent, this was exceedingly frustrating.  But I guess it's the only way you learn.  This is literally the first SMD QFP I've ever soldered, and I had to choose one with 0.5mm pitch to start...
Online AndyC_772
« Reply #17 on: June 25, 2013, 07:50:31 am »
It sounds as though the problems you had were nothing to do with the pitch of the device, they're almost entirely down to the quality of tools and materials you have available. Soldering a 0.5mm QFP is really quite straightforward if you have the right kit:
- liquid flux. Use plenty, but not so much that boiling it off draws all the heat out of the tip.
- a tip that's clean, not too small, and properly tinned. You should be able to pick up a blob of solder about the size of the head of a pin, and it should wet the surface of the tip and stick to it immediately. If the solder forms a round ball on the tip, clean the tip, and if that doesn't work, bin it and get a new one.
- avoid very small, pointed tips, as they don't hold enough heat. I prefer a chisel tip about 1.0 to 1.5mm diameter.
- if you don't have one already, get a tip tinner/cleaner block - basically powdered solder in a resin matrix.
- the proper technique for a QFP is called "drag soldering", and it's much easier and gives a much better result than trying to solder every pin individually. I'm sure there will be videos on Youtube.
duskglow
  • Guest
« Reply #18 on: June 25, 2013, 07:56:15 am »
The pitch of the device didn't help, but it wasn't too bad once I got it figured out.  I'm pretty good at soldering most things, but as with everything in electronics, there are big gaps in my knowledge that I'm working on closing.  Things like how to solder *right* is one of them.
Offline BravoV
  • +++ ATH1
« Reply #19 on: June 25, 2013, 08:54:09 am »
You should get a proper iron, especially a genuine tip, its like night and day. On a proper tip, once cleaned properly, the molten solder will actually flow and sucked into the tip nicely.
For an example, just watch the little nice video at the bottom at this page and see how the molten solder stays and sticks at the coated tinned area of the tip -> http://www.hakko.com/english/maintenance/topic_difference.html
About tip shape, my personal favorite is sharp knife style, its perfect for these tiny pitch pins, here is a really good example -> http://www.hakko.com/english/tip_selection/type_k.html , there are many small videos in this page demonstrating the use of this knife style tip, for example like this one -> Here, highly recommended to watch them all at that page.  :-+
Edit :
On Hakko's various tip styles, the knife style is the most efficient for the heat transfer, hence its also has the best heat regulation compared to other styles, posted this at other thread -> Here
« Last Edit: June 25, 2013, 09:56:00 am by BravoV »
Offline nctnico
« Reply #20 on: June 25, 2013, 04:25:13 pm »
That sounds really bad. You need a temperature controlled iron at 330deg Celcius and a big tip. People often tend to use a tip which is too small. I usually solder 3 or 4 pins of a QFP at the same time.
duskglow
  • Guest
« Reply #21 on: June 25, 2013, 08:44:23 pm »
Took all of your advice - lots of flux, blade tip, and the second one went really smoothly.  Still some stuff to learn but I'm proud of this one.
Offline c4757p
  • adieu
« Reply #22 on: June 25, 2013, 08:46:52 pm »
Not bad! :-+
duskglow
  • Guest
« Reply #23 on: June 25, 2013, 08:50:13 pm »
Not perfect, but there are no shorts and a spot check shows good continuity on random pins...  so now I can get to prototyping. :)
... and I think I need to order more chips. :(
The other one works, but looks way more rough.  I'll use this one first and use the other as a backup.
Offline Galaxyrise
« Reply #24 on: June 25, 2013, 08:59:33 pm »
What kind of liquid flux is good for that? I've got something like http://www.circuitspecialists.com/835-100ml.html and it leaves this dark crust behind that I either ignore or have to chip off with a knife/screwdriver.
I am but an egg
