I brought home a damaged industrial device used to clean glass bottles. It is a kind of mini autoclave that allows water washing at 120°C.
I fixed it, and I did an interesting experiment with continuous cleaning cycles:
1. autoclave-open, pre-wash with water + 20% industrial bleach at 24C
2. autoclave-open, steam water at 100°C
3. autoclave-close, controlled pressure, washing at 120°C
4. autoclave-open, air cooling
5. 50 minute pause
6. visual inspection, every 10 cycles
7. repetition
All automated and controlled by an industrial PLC.
Two guinea pigs
- a stainless steel bar
- a titanium bar 3-2.5
After ~60 cycles {~ 6 inspections} the steel bar starts to corrode, not much but it's starting to be noticed, while the titanium bar shows absolutely no defects
This is very interesting - prolonged use of bleach corrodes stainless steel? *very* interesting - for the cleaning procedure I use, adding bleach to the pre-wash and a steam of water, both save 5 minutes and make the process more efficient, then I autoclave the water at 120 °C, for another 5 minutes, 10 minutes in total to automatically clean the water bottle.
It's crazy as hell, but I love this thing where I come home, put my bicycle in a hot air tent to dry the water off, put my water bottle in that contraption, and while those two PLC-controlled machines are working, I can take a shower and relax, and when I come back it's all work that I don't have to do.
