I have a moderately large DC power supply, 80V 20A. It can be wired for either 120V or 240V. The instructions were rather simplistic and I blindly followed them...
There are two reds and two blacks on the primary. The secondary is already wired to an unregulated dual output rectifier circuit with large filtering caps.
I wanted to wire for 240V and the instructions said to take any red and a black and connect them together, then take the remaining red and black and connect them to the two hots. I did not quite get that "a" black had to be "the" specific black, and the way they came out of the torroid was not obvious. Naturally, we know why I'm posting...
OK, after taking a deep breath, I threw the switch, the lights went dim, and my torroid started making rice krispy sounds. I saw a slight puff of smoke, and quickly shut the mess off. Then it dawns on me that there are two individual primaries that needed to be wired in series, and all I did was wire them in parallel reverse polarity
I undid the mess and wired it up correctly and it seems to power up fine. None of the components on the output seemed to be blown up, and the DC voltage with moderate load seems just fine.
But, I saw smoke and I'm sure something bad has happened. I suspect some of the winding insulation has burned, and I am sitting on a ticking time bomb before it melts down an destroys the stuff on the output. Does this seem about right? Or is this just a bit Chicken Little?
