Author Topic: I need to find the male plug for this connector  (Read 1695 times)
Offline firehopperTopic starter
« on: March 08, 2018, 04:30:09 pm »
its used in pride/curtis/quantum power chairs as the charging port/programming port.
Offline ebastler
Re: I need to find the male plug for this connector
« Reply #1 on: March 08, 2018, 05:55:15 pm »
Indicating the size of the connector might be helpful. Is it a DIN-sized diameter, or something larger? (I found a few high-current DIN connectors, but with 4 pins max.)
« Reply #2 on: March 08, 2018, 06:02:26 pm »
dang it, knew I forgot something, its actually xlr sized.
Offline ebastler
« Reply #3 on: March 08, 2018, 06:40:22 pm »
Hmm, that one is more elusive than I would have thought. I'm afraid my Google-fu is not strong enough -- plenty of military-style hybrid connector but none of them looks quite right. I'll keep my fingers crossed that someone finds this thread who has actually seen those connectors in the wild before!
« Reply #4 on: March 09, 2018, 01:25:20 pm »
found a cable with the connector I need.. yay!
https://howlandtechnology.com/store/1313-cable-xlr.html
Offline ebastler
« Reply #5 on: March 09, 2018, 01:38:20 pm »
« Reply #6 on: March 09, 2018, 03:06:09 pm »
but yeah apparently its a propitary plug or something, really frustrating to try and find..
Offline German_Engineer
« Reply #7 on: May 06, 2024, 05:34:49 pm »
I had the same problem with a Pride Quantum Q-logic 3 wheelchair. The connector is an XLR plug with 3 pins (Mainly for audio applications). It has two additional pins with a smaller diameter for the CAN bus interface. The pins are at a non-standard position. I searched the catalogues of known XLR plug suppliers without success - this must be a custom design. In the end, I put together a standard 3-pin XLR plug and two wire ferrules (white, outer diameter 1.5mm) as shown in the pictures. Some patience with a key file and epoxy did the job. The pinout (CAN-H, CAN-L , GND) is also shown in the pictures.
I figured out the CAN messages for the joystick and for the speed of the left and the right wheel (see attached DBC file and two screenshots from MATLAB CAN Explorer). I am interested in any information about other CAN messages or CANopen OD/EDS/DCF of this or similar wheelchairs with Curtis Instruments hardware to help a university project for automated driving functions. It would be great if you could point me to a forum dealing with such topics.
« Last Edit: May 06, 2024, 06:12:11 pm by German_Engineer »
