Author Topic: Epson LCD question.  (Read 3922 times)
Offline firewalkerTopic starter
  • Country: gr
Epson LCD question.
« on: December 01, 2011, 08:48:54 pm »
I have the following EA-D20025PR-S Epson LCD.
It states that it is HD44780 equivalent using the SED178 controller so I guess the existing libraries for the HD44780 will do the job.
The pin arrangement is like:
The thing is that I can't find the datasheet in order to identify the I/O. The SED1278 isn't accessible (epoxy coated embedded ic) in order to use a multimeter continuity mode.
Does anyone ever used such an LCD? Any help on the datasheet?
Alexander.
Offline Balaur
Re: Epson LCD question.
« Reply #1 on: December 01, 2011, 09:03:56 pm »
Hello,
I would hazard to say that the pinout is the other standard HD44780 pinout as shown here
Check whether the ground connection as indicated in the pinout makes sense.
Cheers,
Dan
« Last Edit: December 01, 2011, 10:15:48 pm by Balaur »
  • Country: gr
« Reply #2 on: December 01, 2011, 10:04:57 pm »
Thanks m8! It works!
Alexander.
