Author Topic: I really miss 1,1,2-Trichloro- 1,2,2-trifluoroethane.  (Read 966 times)
Offline HousedadTopic starter
« on: January 24, 2026, 11:13:20 pm »
Best dang solder flux cleaner ever made.  Sprayed it right off completely in a single pass.
They always take away the good stuff.
« Last Edit: January 24, 2026, 11:15:31 pm by Housedad »
At least I'm still older than my test equipment
Online coppercone2
  • √Y√... 📎
Re: I really miss 1,1,2-Trichloro- 1,2,2-trifluoroethane.
« Reply #1 on: January 25, 2026, 12:15:59 am »
ultrasonic technology gives some dignity back
Online Analog Kid
« Reply #2 on: January 25, 2026, 12:42:54 am »
I do too. (Have some Kodak film cleaner here, with 1,1,2-trichloro-1,1,2-trifluoroethane and heptane.)
Works great.
I don't miss it, though: stuff's too damn carcinogenic.
Same with the good paint stripper, methylene chloride. Nasty shit but it sure works well.
Offline tooki
« Reply #3 on: January 25, 2026, 12:43:56 am »
Indeed. At work, where I have an ultrasonic cleaner now, I have been using water-soluble no-clean flux more and more, because it comes right off in hot water, and the ultrasound gets it out from under ICs and whatnot.
Otherwise, regular flux and Safewash aqueous cleaner does a flawless job.
Offline tom66
« Reply #4 on: January 25, 2026, 12:59:08 am »
Kind of like asbestos.  Like, aside from the terrible human toll it had, it was actually a pretty damn great material.   Fire retardant.   Chemically resistant.  Strong.  Easy to work with.  Versatile.  Inexpensive.  It's just... yeah.  You can't work with it safely, it tears your lungs into pieces and gives you cancer...
Offline themadhippy
« Reply #5 on: January 25, 2026, 01:28:34 am »
Also gets your homebrew wine crystal clear
Online Analog Kid
« Reply #6 on: January 25, 2026, 01:30:58 am »
Same thing with tetraethyl lead.
Offline Whales
    • Halestrom
« Reply #7 on: January 25, 2026, 05:25:10 am »
"If it doesn't cause cancer then it's not safe to use in aircraft"
Offline aeg
« Reply #8 on: January 25, 2026, 07:00:21 am »
Now wait just a minute. 1,1,2-Trichloro-1,2,2-trifluoroethane is Freon TF, a non-toxic, non-carcinogenic, ozone-depleting CFC. It's trichloroethylene that's the nasty carcinogenic neurotoxic stuff.
The following users thanked this post: amyk, ebastler, tooki, Housedad, marhuum, paul cotter
Offline amyk
« Reply #9 on: January 25, 2026, 07:31:05 am »
Carbon tet and many other chlorocarbons are also carcinogenic to varying extents, although not all of them. Too bad they all have a rather pleasant smell.
Offline SteveThackery
  • 50 year novice
« Reply #10 on: January 25, 2026, 01:21:37 pm »
1-1-1 trichloroethane was a damn good solvent. I miss it.
Did you know it was a brilliant fly killer? Put it in a sprayer and spray it at a house fly or bluebottle in flight: the buzz stops immediately and the fly falls straight to the floor, dead. Brilliant.
The following users thanked this post: paul cotter
Offline SiliconWizard
« Reply #11 on: January 25, 2026, 04:22:00 pm »
Yes. It's pretty safe. The only reason it got banned is because it's a CFC and so yes, because of the ozone-depleting effect.
Trichloroethylene, OTOH, is awful.
Offline NE666
« Reply #12 on: January 25, 2026, 06:40:03 pm »
Acetone too.
A lot of the more volatile organics have that effect as they are very soluble in the chitin of the insect exoskeleton, and as a vapor rapidly find their way into the spiracles and air chambers, giving them what becomes effectively a huge overdose of general anesthesia.
Offline jonpaul
    • IEEE Spectrum
« Reply #13 on: January 25, 2026, 06:59:15 pm »
Polychlorinated Biphenyls PCB,  were banned decades ago due to cnacer risk.
They were the VERY BEST insulating oil used widely in power transformers, PFC capacitors, HV caps, etc.
The "safe" substutes are not nearly as good, just 3-10x cost
Jon
The Internet Dinosaur..
passionate about analog electronics since 1950s
Offline David Hess
  • DavidH
« Reply #14 on: January 25, 2026, 09:15:36 pm »
Wikipedia used to say that it was the best damn insecticide ever.  I was very happy with it dealing with wasps, instant death.
What are they using for brake cleaner these days?  It might be acceptable.
Things like acetone and toluene work well but also tend to attack plastics, and are very flammable.
Online Analog Kid
« Reply #15 on: January 25, 2026, 10:15:18 pm »
Acetone too.
I used to shy away from using acetone because I thought, mistakenly as it turns out, that it was much more harmful than, say, naphtha because of its pungent and volatile-smelling odor.
Turns out it's actually safer than a lot of other solvents, so I use it now without much hesitation.
Certainly safer than any chlorinated hydrocarbons.
Our bodies actually produce acetone under some circumstances.
Offline Zero999
  • 0999
« Reply #16 on: January 25, 2026, 11:12:46 pm »
Acetone too.
Plain old orange oil also kills insects and is a good solvent, which is capable for dissolving polystyrene. I've noticed a polystyrene foam cup had started to dissolve and go tacky, when I left an orange peal in it.
  • 50 year novice
« Reply #17 on: January 25, 2026, 11:14:24 pm »
Acetone too.
That's good to know - I've got plenty of acetone. I don't know if flies have the capacity to suffer, but normal fly spray does deliver a prolonged and ugly death. Acetone seems to be much more humane.
« Last Edit: January 25, 2026, 11:16:06 pm by SteveThackery »
Offline tom66
« Reply #18 on: January 25, 2026, 11:15:50 pm »
Just be aware acetone attacks plastics (especially acrylics) badly.  I once spilled a teaspoon of acetone on an Ikea coffee table and the fake laminate came off like it was liquid.  I've done similar with IPA and not had the same effect.
  • 50 year novice
« Reply #19 on: January 25, 2026, 11:18:17 pm »
Absolutely agree. If you are using it for cleaning purposes, it's best to avoid any kind of plastic.
Offline UnijunctionTransistor
  • Ohms Law: Resistance is futile.
« Reply #20 on: January 25, 2026, 11:29:47 pm »
Radium;
That soft green glow that requires no power.
Offline amyk
« Reply #21 on: Yesterday at 04:13:04 am »
There are two types, "flammable" and "non-flammable". The former is usually hexane-ish hydrocarbons, while the latter is perchloroethylene. Both are extremely good at killing insects by suffocating them.
Offline NE666
« Reply #22 on: Yesterday at 09:19:35 am »
Debatable. Their CNS is very rudimentary but still has the capacity to respond to harmful stimuli, perhaps even 'remember' the same according to some studies. At what point a brain becomes complex enough to experience the concepts of trauma and suffering, I have no idea.
However, on a relative scale, acetone etc. are more akin to being put under with ether or chloroform (which still can't be pleasant) rather than being dosed with a nerve agent. Which is what fly sprays using pyrethroids effectively are.
Offline paul cotter
  • Country: ie
  • retired but still get called upon occasionally
« Reply #23 on: Yesterday at 10:34:49 am »
1,1,2 trichloroethylene was used as an anaesthetic for a long time. Replaced now with various fluoroethers such as sevoflurane, enflurane and others. It cannot have been that toxic. The most toxic probably was carbon tetrachloride with tetrachloroethane supposedly bad also. 1,1,1 trichloroethane is supposedly one of the least toxic but really bad for ozone depletion.
  • 50 year novice
« Reply #24 on: Yesterday at 11:30:42 am »
Just to confuse matters, "ethylenes" are now "ethenes". So trichloroethylene is now trichloroethene and polyethylene is polyethene.
