Hello all,
I'm wondering if someone could provide insight or experience on constructing and using a Kelvin Bridge? I have the need to measure the contact resistance of many large low voltage breakers (100-3000A, 120-480v) and am a bit put off by the cost of commerical milliohmeters. As such, I want to build myself a device for 4 point measurement of resistance, which I understand to be a Kelvin Bridge. I get the basic layout and concept of it, however all the pics I've seen show it being used on a 4 wire resistor. I can't wrap my head around how I can apply that to the two terminals of the single pole of a breaker?
I'm familiar with doing a caveman style 4 point test: supply a known/controllable current to the item under test, then measure voltage drop across the test item while it is energized. I'm hoping there's something that I can make a bit more unitized to keep with me in the field.
Any suggestions? Thanks!
