Author Topic: I used to laugh at idiots ordering the wrong package size...  (Read 1712 times)
Offline nessatseTopic starter
« on: March 26, 2021, 12:45:08 pm »
Not any more
The following users thanked this post: MK14
Offline tszaboo
Re: I used to laugh at idiots ordering the wrong package size...
« Reply #1 on: March 26, 2021, 12:54:52 pm »
The only ones who didn't order the wrong package are people who didn't order enough components.
Same goes for putting part numbers in the BOM.
The following users thanked this post: nctnico, m98, newbrain, NivagSwerdna
Offline Ian.M
« Reply #2 on: March 26, 2021, 01:14:26 pm »
How lovely, an 0.8mm square leadless package.  If you are in a hard time-crunch, you could 'dead bug' it on a glue dot and hook it up with 38AWG magnet wire.  It would be a PITA, but just about practical for a one-off prototype.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #3 on: March 26, 2021, 01:32:25 pm »
Yes, we've all been there...
One of my latest was when I making a laptop FDD flat cable converter from 26 to 22 pins (different pitches) and I ordered exactly the opposite pin count/pitch. |O
The following users thanked this post: HobGoblyn
Offline Bud
« Reply #4 on: March 26, 2021, 01:52:22 pm »
Once needed a reel of 0805 resistors, ordered a reel of 0201 size instead  |O
Offline Gribo
« Reply #5 on: March 26, 2021, 01:57:01 pm »
Well, it is better than ordering 0603 Metric instead of 0603 Imperial...
I am available for freelance work.
Offline asmi
« Reply #6 on: March 26, 2021, 02:57:57 pm »
I often mess up SOD-x23 and SOT-x23 packages. Hate them with passion! :box:
Offline nicknails
« Reply #7 on: March 26, 2021, 03:24:34 pm »
Ha! I did the same thing, could barely see the part!
Online coppercone2
« Reply #8 on: March 26, 2021, 06:07:58 pm »
Some how I made a NASA grade error with choosing a switch, in the sense of unit mixup. I wanted a panel mount thing to fit into a box (multi switch). I thought it would be the size of a silver dollar and it turned out to be about 1/4 of a fosters beer can.
This happens because you think simple component, loose tolerance, you can't fudge it. I must have thought metric = imperial.
Great switch though, just the box was too small.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #9 on: March 26, 2021, 06:53:08 pm »
Don't drop it on the floor!
-Pat
Offline Red Squirrel
« Reply #10 on: March 26, 2021, 07:13:41 pm »
LOL I did a similar mistake.  Except I had dimensions and everything so it's 100% my fault.  I pretty much grossly underestimated just how small 5mmx5mm is when you are trying to dead bug solder it.  Pretty much need a PCB with proper solder pads for something like that.  I'm sure someone that's very good at soldering could dead bug it but it was a little beyond my skillet lol.
Offline SilverSolder
« Reply #11 on: March 26, 2021, 07:45:06 pm »
And I always have a good laugh when idiots draw the wrong footprint, until I met this part.
Amazingly, it didn't blow up or short out the supply rail upon power on. I guess it has good DFI (design for idiots).
FYI, it's Bosch BNO055.
"Pin 1 II" ??  :D
Offline thm_w
  • Non-expert
« Reply #12 on: March 26, 2021, 09:37:08 pm »
"Pin 1 II" ??  :D
"Pin 1 ID" in the datasheet.
Pin 1 is NC in the datasheet, so.. I assume the ID pad is NC as well but not really sure. Interesting choice, maybe it helps with pick and place bottom cameras?
