Author Topic: ICOM IC-7000 Letting The Smoke/Flames Out! (Old Video)  (Read 4705 times)
Offline KG7AMVTopic starter
  • Rhine_Labs
    • My Personal Blog
« on: November 23, 2014, 08:05:29 pm »
This happened to me a few years ago while on the ramp in Oakland, CA!
This Icom IC-7000 was installed on in a Commander 114 I was bound to Australia. As Procedure I always contact San Francisco Airinc on HF on the ground and Video or Audio record the response from them CMA in case of lost coms!
Commander 114 Photo.
When I seen the smoke and flames I killed the main power! The Hookup was to a 24V to 12V 20A Astron Converter, SGC-237 Coupler with Better RF Tune Control and Long Wire Antenna! Ham Radio Outlet was just down the road grabbed the crew car went and got a new one and continued the trip to the Gold Coast!
I was thankful that ICOM Replaced this radio with a new one after about a year wait! But would have been a big repair! The replacement has had its 3 trans pacific trips and now has been retired to the ham shack! Icom said that the radio Self-Oscillated still unknown reason they would not tell me.
Video of  ICOM IC-7000 Self-oscillation on RX Video
http://stevenrhine.com/Icom%20IC-7000/IC-7000%20%20Smoke%20Self-Oscillation%20On%20RX.MOV
Damage to PA board.
« Last Edit: November 23, 2014, 08:28:46 pm by KG7AMV »
Offline Howardlong
Re: ICOM IC-7000 Letting The Smoke/Flames Out! (Old Video)
« Reply #1 on: November 23, 2014, 08:22:18 pm »
At least you were still on terra firma, and not over a vast expanse of ocean, and were able to shutdown quickly and safely.
Time for analysis is definitely not on your side in those situations, particularly after takeoff.
I guess that's a good reason why they use PTFE wiring in certified panel mounted kit.
  • Rhine_Labs
    • My Personal Blog
« Reply #2 on: November 23, 2014, 08:27:49 pm »
Sorry about the blurry first photo's found the SD card with the good ones!
The wiring I use is aircraft grade tefzel (Teflon). Yea, glad I was on the ground but I could have shut it down regardless I have the radios in portable kits and there is a heavy duty toggle for power in reach at all times. With 160 gallons of 100LL in the cabin not a place for flames!
How an IC-7000 Install Looks in a Mooney M20TN
« Last Edit: November 23, 2014, 08:44:21 pm by KG7AMV »
Offline Howardlong
« Reply #3 on: November 24, 2014, 10:19:26 pm »
Unfortunately the UK amateur licence doesn't allow operation from aircraft. In addition, I would doubt that the permanent fitting of non-ETSO authorised kit in the panel is allowed on EASA aircraft. We get away with that by running spaghetti wiring from the lighter outlet and several suction mounts. Typically I run a Garmin 495 and an iPad this way.
Of course, I could always get a US callsign and re-register the plane as an N-reg...
  • Rhine_Labs
    • My Personal Blog
« Reply #4 on: November 24, 2014, 11:30:26 pm »
We do the temp installs for Ferry Flights (Special Flight Permit & Special Airworthiness Certificate) under a FAA Field Approval.
