Author Topic: Idea for a first YouTube Video  (Read 6527 times)
Online nctnico
Re: Idea for a first YouTube Video
« Reply #25 on: March 24, 2024, 12:38:11 am »
I’ve been inspired by a recent thread to start my own YouTube channel. I’d welcome your thoughts on a possible first video. A possible script and indication of the visuals are....
Video Title: Review of the New Bus Pirate 5
I’ve occasionally thought it would be useful to have a Bus Pirate for quick-and-dirty peek/poke and protocol analysis of modern communications over busses like SPI, I2C. I’ve hesitated because the Bus Pirate 3 is distinctly long in the tooth, but the Bus Pirate 4 “upgrade” can’t do as much as the Bus Pirate 3.
So, what do you think? Should I do it?
Which of these channel names do you think would be most appropriate?
MyTimeIsMoreValuableThanYours
LookAtMe
WotACleverDudeIAm
YetMoreMonetisedClickbait
How about MoreUselessVideos?  >:D It seems your script doesn't include any actual testing. When doing a review, I work according to a test plan (crafted to verify the instrument's specifications and beyond) to go through the functionality and limits of a piece of test equipment. For an oscilloscope that means a couple of days work for doing just the tests. Along the way the testing also provides a good feel of how the instrument operates and where the UI is good or bad.
Offline shabaz
« Reply #26 on: March 24, 2024, 12:43:58 am »
Regarding camera on tripod, although I agree, just to play devil's advocate, some manufacturers prefer short product reviews to be done with a mobile phone, slightly shaky being OK, because that's 'keeping it real', i.e. seems a more authentic genuine review, than a polished presentation. Perhaps that works well for short 'how-to' videos sometimes, for particular single features, or a quick 'unboxing' (I don't usually watch those, but they are occasionally helpful to get a quick overview of what's going to be supplied with the product).
Also, sounds superficial/cruel to say, but this is also why, even for official videos, they prefer to choose someone that they believe looks average rather than good-looking.
Offline Sredni
  • Country: aq
« Reply #27 on: March 24, 2024, 01:22:54 am »
Oh, so that's why Allie is not doing those Keysight scope tutorials...
The following users thanked this post: pdenisowski
Online tggzzzTopic starter
« Reply #28 on: March 24, 2024, 01:41:05 am »
LookAtMe
WotACleverDudeIAm
Why the "  >:D "?
It doesn't have any testing. It is an the feeling of unboxing and getting it to work. I'm trying as best I can to fit into the zeitgeist of modern youtube.
Mind you, I'm having trouble with the config experience being real-time and staying within the set limits. Currently I've spent several hours pissing around with the udev filters, without success. I've had some suggestions on the BP5 forum, but so far they haven't panned out.
There are two USB interfaces, one text the other binary, and it is pretty random which one minicom (terminal emulator) connects to. The workaround is to connect the terminal to /dev/ttyACM0; presumably the binary interface is /dev/ttyACM1.
While the syntax of the udev rules seems simple, I haven't spotted an explanation of the semantics and how that maps onto USB hierarchical structures. Once upon a time I might have bothered to learn that, but the attraction of learning yet another scrotty little Domain Scripting Language and underlying structures doesn't appeal to me.
The following users thanked this post: shabaz
Online nctnico
« Reply #29 on: March 24, 2024, 01:54:09 am »
Where it comes ACM interfaces, the best thing to do is make a udev rules which makes a symlink in /dev to a device entry you name yourself. So (for example) the text interface is on /dev/bp5-text and the binary on /dev/bp5-bin
What the rule is based on (USB interface) or a unique device feature depends on what you want and/or which unique features are available.
If you have multiple devices, you may want to add numbers but that is the next step.
« Last Edit: March 24, 2024, 01:57:31 am by nctnico »
Offline shabaz
« Reply #30 on: March 24, 2024, 02:47:28 am »
EDIT: Please ignore this message, it's not a solution (it won't work when additional ttyACM's from other devices are present).
I'm using Windows normally, but gave it a shot, this is currently working for me (with Ubuntu):
I plugged in the BP5, and typed (a wide screen is needed, otherwise it will truncate the grep'd result on the right side!):
udevadm info /dev/ttyACM0 | grep ttyACM1
I made a note of the line containing DEVPATH= and then typed:
udevadm info /dev/ttyACM1 | grep ttyACM1
For me, the two results were:
/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.2/1-1.2:1.0/tty/ttyACM0
/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.2/1-1.2:1.2/tty/ttyACM1
Then, I created (as root user) in folder /etc/udev/rules.d a file called 97-buspirate.rules:
# BP5 udev rules file
SUBSYSTEM=="tty", ENV{ID_VENDOR_ID}=="1209", ENV{ID_MODEL_ID}=="7332", MODE="0666", DEVPATH=="/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.2/1-1.2:1.0/tty/ttyACM0", SYMLINK+="bp0"
SUBSYSTEM=="tty", ENV{ID_VENDOR_ID}=="1209", ENV{ID_MODEL_ID}=="7332", MODE="0666", DEVPATH=="/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.2/1-1.2:1.2/tty/ttyACM1", SYMLINK+="bp1"
Then (still as root user) type:
/etc/init.d/udev restart
Then, un-plug and then re-insert the BP5, so that things take effect.
Since I don't know how to use minicom, I did (as root user)
apt install screen
Then, as a normal user, type:
screen /dev/bp0
The Bus Pirate text menu appears. To exit screen, press CTRL+A, then press \ then press y
I didn't see the VT100 colors, but I think that's a problem with my terminal settings, I was SSH'ing in to the Linux box from a Windows PC, using SecureCRT. Ordinarily I will use it with Windows, and in that case, MobaXterm displays the colors. SecureCRT doesn't for reasons I've not got to the bottom of, but at least there is the MobaXterm workaround.
EDIT: p.s. the LEDs are slowly growing on me! : ) Working in a dimly-lit room, it looks like something alien..
« Last Edit: March 24, 2024, 03:14:17 pm by shabaz »
The following users thanked this post: BILLPOD
Offline jonovid
    • JONOVID
« Reply #31 on: March 24, 2024, 03:38:40 am »
full time youtubers incessantly begging for money, obsessed with becoming the next mrbeast  ::)
if you must do it full time specialize in one thing really well . know your subject better than the average viewer.
do you have a voice for radio or a face for television?  then welcome to the entertainment industry.
 if not, don't give up your day job IMO.
if like Me posting the odd yt video is just for the fun of it, not for profit hobby.
Hobbyist with a basic knowledge of electronics
« Reply #32 on: March 24, 2024, 08:59:09 am »
Knowing the subject better than the average viewer doesn't seem like a difficult hurdle to jump.
I think I have a TV/radio face/voice. Besides, the evidence is that it isn't important.
« Reply #33 on: March 24, 2024, 10:24:24 am »
Don't forget to get Brilliant as a sponsor. ::)
And NordVPN as a second sponsor.   :-DD
« Reply #34 on: March 24, 2024, 10:27:34 am »
Looking forward to this new channel, so that I can start a reaction channel featuring it
The following users thanked this post: nctnico, BU508A
Online nctnico
« Reply #35 on: March 24, 2024, 10:53:10 am »
This is not going to work. As soon as you plug a phone in or any other device that registers as an ttyACMx, the numbering will be off. You'll need to look for some kind of sub-device ID and use that for matching. So vendor id, model id and sub-device number should be used for the udev rule to make it universal. That way no matter which ttyACM the BP5 is assigned to, the symlinks will always work. You can also include the serialnumber (if the USB device has one) and have specific devices attach to specific symlinks.
« Reply #36 on: March 24, 2024, 12:04:39 pm »
That was my presumption as well.
I haven't seen any definition of the mapping between what tools tell me is on the usb bus, and what can be put in a filter. So what would be suitable filters, given
usb-devices output is
T:  Bus=01 Lev=01 Prnt=01 Port=04 Cnt=02 Dev#= 16 Spd=12  MxCh= 0
D:  Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=1209 ProdID=7332 Rev=01.01
S:  Manufacturer=Bus Pirate
S:  Product=Bus Pirate 5
S:  SerialNumber=123456789012
C:  #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=100mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=00 Driver=cdc_acm
I:  If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
I:  If#= 2 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=00 Driver=cdc_acm
I:  If#= 3 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
I:  If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
Or the usbview output is
Bus Pirate 5
Manufacturer: Bus Pirate
Serial Number: 123456789012
Speed: 12Mb/s (full)
Bus:   1
Address:  16
USB Version:  2.00
Device Class: ef(misc )
Device Subclass: 02
Device Protocol: 01
Maximum Default Endpoint Size: 64
Number of Configurations: 1
Vendor Id: 1209
Product Id: 7332
Revision Number:  1.01
Config Number: 1
Number of Interfaces: 5
Attributes: 80
MaxPower Needed: 100mA
Interface Number: 0
Alternate Number: 0
Class: 02(comm.)
Sub Class: 02
Protocol: 00
Number of Endpoints: 1
Endpoint Address: 81
Direction: in
Attribute: 3
Type: Int.
Max Packet Size: 8
Interval: 16ms
Interface Number: 1
Alternate Number: 0
Class: 0a(data )
Sub Class: 00
Protocol: 00
Number of Endpoints: 2
Endpoint Address: 02
Direction: out
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Endpoint Address: 82
Direction: in
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Interface Number: 2
Alternate Number: 0
Class: 02(comm.)
Sub Class: 02
Protocol: 00
Endpoint Address: 83
Direction: in
Attribute: 3
Type: Int.
Max Packet Size: 8
Interval: 16ms
Interface Number: 3
Alternate Number: 0
Class: 0a(data )
Sub Class: 00
Protocol: 00
Endpoint Address: 04
Direction: out
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Endpoint Address: 84
Direction: in
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Interface Number: 4
Alternate Number: 0
Class: 08(stor.)
Sub Class: 06
Protocol: 50
Endpoint Address: 05
Direction: out
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Endpoint Address: 85
Direction: in
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Online nctnico
« Reply #37 on: March 24, 2024, 01:42:52 pm »
You can try to look up the ACM devices from the BP5 in sysfs and trace back to the device driver / bus instance they belong to. From there you might be able to spot a useful discriminator to seperate the text and binary interface.
« Reply #38 on: March 24, 2024, 02:39:33 pm »
Well, I have spent too much time trying and failing. Yes, I'm profoundly ignorant of USB and udev, and have absolutely no inclination to change that. Fundamentally this information should be supplied by the manufacturer. Since this is a new device, I will cut them some slack - and wait until a usable workaround is announced.
If it doesn't appear, then I'll point it out. I'll probably be one of many doing that.
I'll just use /dev/ttyACM0 and call it a day.
Offline shabaz
« Reply #39 on: March 24, 2024, 03:09:32 pm »
I didn't think of additional ttyACMs, good point.. I can't find a way to do it either : (
I could only come up with this not-so-great workaround. I have tested by inserting another ttyACM device, and it seems to function OK (replace 'screen' with minicom etc), and save with 755 permissions or similar. I'm not very good with bash so I'm sure this could be improved a lot. It assumes that the lower ttyACM value out of the pair will be for the text console, this seems to repeatably be the case with my BP5. Currently it checks just for ttyACM0 to 9, it's really ugly:
#!/bin/bash
PORT="none"
for i in {0..9}
do
  if udevadm info /dev/ttyACM$i | grep -q 'Pirate'
  then
    echo "Pirate device found at /dev/ttyACM$i"
    PORT=/dev/ttyACM$i
    break
  fi
done
# execute screen on the port if it was found
if [ "$PORT" != "none" ]
then
  screen $PORT 115200
else
  echo "No Pirate device found"
fi
« Last Edit: March 24, 2024, 03:17:57 pm by shabaz »
Online pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #40 on: March 25, 2024, 01:05:08 am »
do you have a voice for radio or a face for television?  then welcome to the entertainment industry.  if not, don't give up your day job IMO.
As someone who's made > 200 technical videos as part of his job:  early on I made the very deliberate decision not to appear on camera, despite many, many, many people telling me that my audience needed to see my face in order to "engage" with me or to keep their attention.  I told them that if the content itself wasn't engaging or interesting on its own, seeing my face wasn't going to make it any better* ....  :-DD
https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
There are successful video creators who appear in person (Keysight's Daniel Bogdanoff or Johnnie Hancock, and of course Dave) and others whose face you rarely see (Alan, W2AEW).  So I think there is room for both types of videos: you have to choose what works best for you.
* For better or for worse, it is actually my voice in all of the videos.  I don't have the budget to hire a voice actor :)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline Sredni
  • Country: aq
« Reply #41 on: March 25, 2024, 01:53:24 am »
Nice presentations.
I agree, the face is not necessary if your content is good.
May I ask you what you use to record these videos?
Offline vk6zgo
« Reply #42 on: March 25, 2024, 02:02:54 am »
I imagine a Jerry Walker style intro section - and a clean-starched-shirted presenter  :-+
I don't know Jerry Walker, but it wouldnt be a clean starched presenter.
As my daughter once said with a strong tone of incredulity, "I didn't know you had an iron!" . I pointed out that I had owned it longer than I had owned her.
I might even wear a 50yo T-shirt, but I could sell it for a surprisingly large amount of money. FFI, spelunk in the TEA thread :)
So this is just a "cunning plan" to sell a collectable  t-shirt?
Online pdenisowski
« Reply #43 on: March 25, 2024, 09:20:53 am »
Almost every video I do is "narrated / animated PowerPoint" which I record using Camtasia.  Quite frankly, I probably use < 5% of Camtasia's features:  the "editing" is just me cutting out the parts where I made mistakes.  I'm assuming that most other screen recording tools would also work.
I do occasionally make "live action" videos and edit those with Camtasia as well.
https://www.youtube.com/shorts/_FschnxSBa4
https://www.linkedin.com/posts/pauldenisowski_keurig-meets-the-rs-hmc8015-activity-7095861292766281728-ti3_/
« Reply #44 on: March 25, 2024, 09:29:54 am »
Not really; it is too fragile, and I could only just squeeze into it.
Eminently fleabayable, though.
There is a picture of it in this forum, but people have asked me not to post it again :)
Online TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #45 on: March 25, 2024, 01:12:05 pm »
My advice... lol
You need more light for the camera. Nope, even more.... Still more... Keep going.... Do your eyes hurt yet? Ok, add some more. ;)
Also, get a good microphone. Good audio makes sub-par video quality look better, but crap audio will make the best video look crap. Ain't the human brain weird? :D
Now, turn on the camera and start talking, keep retaking the video until you get bored, you don't have to do it all in one take. Then chop 90% of the crap away in editing, add a SHORT intro logo if you prefer and upload. Oh, don't forget to up the colour saturation juussttt a little, especially if your lighting is crap.
The next one will be better, I promise. :)
« Reply #46 on: March 25, 2024, 01:25:45 pm »
But I'm trying to capture the zeitgesst of modern youtube channels!
Offline vk6zgo
« Reply #47 on: March 25, 2024, 11:38:55 pm »
You need at least two Bird wattmeters in cascade, plus a CB radio you can key up and say "Aaauuudddio!"whilst you watch them "Bird Watts".
  • Country: jp
« Reply #48 on: March 26, 2024, 07:50:45 am »
Well, if you want to follow the lead of the two best Youtube channels in the world, you'll need an annoying Australian accent like me and Dave. :-DD
Offline drago462
« Reply #49 on: April 15, 2024, 08:12:38 am »
Dude, the magic of youtube is in the clickbate. Keep the same style and upload regularly. By the way, you nail it with the names, like ¨MyTimeIsMoreValuableThanYours¨ its simple hilarious.
