Author Topic: Identifying chip which burned on VIA EPIA CN10000EG motherboard?  (Read 2104 times)
Offline ddsTopic starter
Hello,
By using power supply which was probably with different polarity I've smoked chip on mobo. Cannot identify chip. Does the anybody have a high resolution picture of this motherboard?
Offline Zero999
  • 0999
Re: Identifying chip which burned on VIA EPIA CN10000EG motherboard?
« Reply #1 on: January 05, 2011, 06:49:01 pm »
Is the chip so badly disfigured you can't see the part number?
There are probably other damaged components so even if you replaced the chip, it might not work.
« Reply #2 on: January 05, 2011, 07:56:13 pm »
Chip is foobar...:)
