Hello!
So, I have a need to test and verify surge emunity for certain products. What the product is or how it should be used is irrelevant. However, what isn't is the cost to have these tested.
That is why i want to do my own testing to see if the product meets the requirments. The test follows the IEC standard 61000-4-5:2014 with a 8/20 (8 us rise time, 20 us duration) 10 kA pulse
The test box which i've built consists of a high voltage transformer (6 kV) which charges a bank of very large capacitors (4 uF). The idea is this: When a certain voltage is reached the capacitors should dump all their energy into the DUT (device under test), trough a shaping network, consisting of resistors and inductors. At its current state, the surge process is controlled via a GDT (spark gap). So when a certain voltage is reached, the GDT arces over and the energy gets dumped into the DUT.
However, here inlies the problem. The GDT, altough providing the decired waveform, isn't stable enough to deliver the same peak current into a short curcuit every time. It varies with several kA after every test. Probably since its breakdown voltage varies after every spark.
I want something which can provide a more accurate pulse and do away with the GDT solution completly. And I was thinking about a really beafy IGBT. But they aren't rated for the high current i'm after. And the ones that are, cost as much as a small car.
I'm after a device which can handle a switching current of 10 kA peak with a standard 8/20 us pulse at a 1 minute intervall. And not break down from the 4 - 6 kV that will be across it. Does anybody have experience using IGBT (or similar devices) this far from their working parameters?
Maybe somebody has experience with these kinds of tests and are willing to share some info, that would be fantastic!
