Author Topic: If you repair old TV’s and Radios ya know what these are.  (Read 1525 times)
Offline jdoleckiTopic starter
« on: February 26, 2023, 09:54:47 pm »
Like Spicolie said “My old man is a television repairman, he’s got this ultimate set of tools. I can fix it”[/img]
Offline Benta
Re: If you repair old TV’s and Radios ya know what these are.
« Reply #1 on: February 26, 2023, 10:05:17 pm »
Nice! 1980s?
Offline TimFox
« Reply #2 on: February 26, 2023, 10:50:12 pm »
I have some of the same alignment tools in my kit.
My favorites were the ones with a shroud around the flat blade, and the different-size hexagons on the same stick for aligning J W Miller IF transformers.
Offline floobydust
« Reply #3 on: February 26, 2023, 11:07:33 pm »
What, these are a thing now? I've had these alignment tools for decades  :-//
I have spring tools as well, I doubt people know what those are. That's the only other tools from that era that are somewhat exotic, maybe the PLCC puller.
That camaro is dead lol
Offline Neomys Sapiens
The following users thanked this post: shakalnokturn
Offline CatalinaWOW
« Reply #5 on: February 27, 2023, 12:49:03 am »
I called them twizzlers.  And only had a basic set of a dozen or so.  And on my budget at the time not top of the line, so they always had less torque capacity than needed to get really precise adjustment.
Offline eti
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
« Reply #6 on: February 27, 2023, 12:49:39 am »
Mostly non-conductive (non-loading?) trimmers, a bulb for LOPT / flyback driver loading, a wire brush to aid corrosion clean-up... I am an ex TV/VCR apprentice from the 90s - is this right?
Offline Brumby
« Reply #7 on: February 27, 2023, 01:05:47 am »
That's quite a selection!
I could count the number I had on the fingers of one hand.  Haven't used any of them in years ... and I'm not sure where they ended up.
They're around here somewhere .. .. ..... .............
Offline aeberbach
« Reply #8 on: February 27, 2023, 02:37:57 am »
I used to take my grandmother's plastic knitting needles and grind them down to a screwdriver profile on dad's bench grinder...
Software guy studying B.Eng.
Offline jonpaul
    • IEEE Spectrum
« Reply #9 on: February 27, 2023, 02:47:17 am »
essentiel for calibration of instruments especially analog CRT tektronix scopes and plug-ins circa 1970s..1990s.
Some spécial types had hex tips.for ferrite or powdered iron slugs  in variable coils, or very small dimensions blades for tiny ceramic variable capacitors.
My collection has ~100 types.
Jon
An Internet Dinosaur...
The following users thanked this post: pardo-bsso
Online David Hess
  • DavidH
« Reply #10 on: February 27, 2023, 03:50:58 am »
Diddle Sticks
Tweaky Tools
Offline Stray Electron
« Reply #11 on: February 27, 2023, 03:43:42 pm »
Nice! 1980s?
   Probably closer to the mid1960s!  Very few later techs really knew how to align the tuned circuits in TVs and radios and it was too time consuming to to do it in a repair shop.  I worked for a VERY old TV shop owner in the late 1970s and he was a master at retuning the RF circuits in TVs but he's really the only person that I ever knew that did it regularly and that really knew what he was doing.  He got out the Navy in 1945 and one of the big TV companies hired him and extensively trained him on TV repair and he was one of the TV techs that installed the first televisions in the US, specifically in New York City!
Offline TomKatt
« Reply #12 on: February 28, 2023, 01:18:26 pm »
Mr. Carlson has several videos demonstrating how RF circuits are peaked an tuned.  He's done it using high tech spectrum analyzers and old tech test gear from the 1930's.  TV is really just a fancy radio signal.
 There's a lot to it.
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline unknownparticle
« Reply #13 on: February 28, 2023, 02:22:26 pm »
Trimmer tools.  I have a Philips service set going back to the 70's, essential for alignment work.
DC coupling is the devils work!!
Offline Towger
  • Country: ie
« Reply #14 on: March 03, 2023, 07:52:23 am »
A set of Golden Screwdrivers for magical tweaking of everything which can be tweaked...
Offline EPAIII
« Reply #15 on: March 07, 2023, 06:45:00 am »
Well, I have a few of those, from back then. But that is the dream assortment. Frankly, I never saw it before, even in catalogs.
I often used a file to make the tool needed for a particular coil or capacitor. By reshaping a fiberglass screwdriver.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
