A lot of OH&S limits get set by precedence from accidents, unintentional human experimentation. Then its known for sure what levels of hazard caused the damage and then animal models are used to find rates and thresholds. But feel free to question the entire basis of health research using animal models from your uninformed view point, the rest of us will get on with using the valuable information it provides.
At no point did I suggest that animal experimentation isn't useful, far from it. If this is not validated with experimentation on humans, it renders the resulting data open to questioning. You are introducing more independent variables here, which is the significant differences in traits in species. I see nothing wrong with suggesting that a human experiment will be more accurate, because it should be blatantly obvious that this is the case. Many medical studies are done on humans (commonly known as
clinical trials) for this exact reason.
I'll skirt Godwins Law here and suggest some people are just never satisfied without having the exact data from real experiments on humans. The civilised world has decided thats not a sociable way to do things.
Real experiments on humans are regularly performed in the form of clinical trials, waiting for accidents to happen (often with devastating effects), and people volunteering for experimentation. Some experiments do not scale well if you perform them on rats, mice, and pigs. You don't need to be a doctor to work out that experimental results can (and often do) be challenged if the test isn't scientifically fair.
Not all human experimentation is done in a Unit 731 type environment.
We know that bright light sources can damage peoples vision, whats so hard to grasp here? If you dont like the scientific basis for setting the limits you can try and show how the studies are invalid rather than just dismissing them because you lack the understanding to see how they're relevant.
Again, you are assuming that I am blankly disputing the claim. I am only agreeing that the data can be questioned, and in this case, it has. Bright light sources can damage vision, and has been proven time and time again. The point is whether
blue light can damage vision, not bright lights. I am not disagreeing with that either, just the validity of
only relying on animals.
On that note I first heard about this "blue light hazard" around 10 years ago, and I think human subjects were also studied, but I can't find any links to such a study now. It was also a specific wavelength of blue, near the low-end of the visible light spectrum, at elevated intensity, in concentrations not found in natural light (eg. blue sky).
