Has anyone done the "weird mA value -glass encased springy fuse- rolls off the bench and breaks, or gets crushed on the bench" thing ?
or... you do all the right things, but the metal ends pop off or twist/break due to aged/heat glue failure
Then the hunt and wasted time/fuel to find another asap to finish the job,
and or test to see if another T or F value will suffice,
and or be better rated than the factory fitted one
and then there's the 'you can't buy these fuses in singles' thing
and have to fork out for an overpriced 3 or 10 fuse packet,
which leads to a 'short fuse' situation years later
not being able to find them to use in another similar fuse scenario
...I reckon some people have jumped off bridges for lesser reasons
