Author Topic: impedance problem in suez canal  (Read 7143 times)
Offline joseph nicholas
  • Country: mx
Re: impedance problem in suez canal
« Reply #50 on: March 29, 2021, 11:18:23 am »
Get some old hippies from the 60's to levitate the thing like we did to the Pentagon.
Offline Kleinstein
« Reply #51 on: March 29, 2021, 12:09:42 pm »
Why not use camels?
The Arabs should know about camels  :-DD, but the ones in charge are dutch.
With the ship now so close to the bank it is likely no longer an option. It may have been an option initially, but at the size of the ship it would need sizable ones and they are likely no available so fast.
Online coppercone2Topic starter
« Reply #52 on: March 29, 2021, 12:40:31 pm »
if thats not fake or hacked post fact then the ship got hacked prior to the fact or there is a seriously disgruntled employee or its just a joke (captain told to burn time). Its too funny for a coincidence.
https://www.snopes.com/fact-check/cargo-ship-ever-given-penis/
« Last Edit: March 29, 2021, 12:46:52 pm by coppercone2 »
Offline themadhippy
« Reply #53 on: March 29, 2021, 12:43:06 pm »
maybe a reverse dutch solution,instead of a little boy with his finger in the dyke,have loads of little boys pissing in  the canal to raise its level
Offline Vovk_Z
  • Country: ua
« Reply #54 on: March 29, 2021, 02:13:31 pm »
https://www.msn.com/en-us/autos/news/massive-ship-blocking-the-suez-canal-has-been-freed/ar-BB1f41PC?utm_source=fark&utm_medium=website&utm_content=link&ICID=ref_fark
- I'm sure it happened only because of a several very helpful advises in this topic.
And several possibilities (for example, with Atlas V) were wasted.
« Last Edit: March 29, 2021, 02:15:26 pm by Vovk_Z »
« Reply #55 on: March 29, 2021, 03:38:40 pm »
its free
Offline Alex Eisenhut
  • Place text here.
« Reply #56 on: March 29, 2021, 05:53:50 pm »
Uh oh, did someone call the USS Harry S. Truman and let them know they can turn back?
Offline coppice
« Reply #57 on: March 29, 2021, 06:06:24 pm »
I'm no naval engineer but it seems to me there should be a rule of thumb that you don't try to enter a body of water that is narrower than the length of the ship.  In perfect conditions as long as ship stays straight I guess it's fine but in this case they definitely got themselves in a kerfuffle and jackknifed her good!   We're gonna need a bigger tugboat.
They'll probably need to bring in a large dredging ship or similar to try to get it out I imagine.
Whether they are seawater canals for huge ocean going vessels, or inland canals for vessels specifically designed for canal only use, it has always been normal for canals to carry ships longer than the width of the canal. Canals cost serious money. Making them any wider than is necessary for 2 vessels to pass each other safely would make most of them too costly to be viable.
Offline Gyro
« Reply #58 on: March 29, 2021, 06:11:49 pm »
Best Regards, Chris
Offline Kleinstein
« Reply #59 on: March 29, 2021, 07:08:30 pm »
Some canals are not even wide enough that 2 of the larger ships can pass. So they have to operate at last parts in one way mode. This is the usual way for the suez canal. They are in the process to widen the longer northern part, so that they can go both directions at the same time, at least for that part.
If the ship is much longer than the canal is wide, the ship can not longer so large an angle to hit the banks - so it gets a little safer. The ship was not too long - it was too short. :-DD
Offline coppice
« Reply #60 on: March 29, 2021, 07:22:04 pm »
Yeah, its common for there to be canal sections, over things like viaducts, which operate for a while in one direction and then a while in the opposite direction, to minimise construction costs. There are also spots geographically constrained for width which are one way at a time. Locks, except in the busiest location, are usually one way at a time. The local canal where I was a kid had an odd arrangement of double locks for some locations interspersed with single locks for others. I guess when the system was first built some sections were expected to have massively more traffic than others.
Offline harerod
  • ee - digital & analog
    • My services:
« Reply #61 on: March 30, 2021, 07:20:02 am »
Applying Cunningham's law: As so often with Japanese humor - I don't get it. So I will post a possibly wrong answer and hope to be corrected.
"バズった怪しい研究" - "(their) Weird experiment went viral"
"間違いの指摘" - "(now they are) pointing out (someone else's minor) mistakes"
Why bother putting this picture here? Well, I hate total surveillance. I mean that could have been me, a quarter century ago. Working in a place with lots of sand, the next toilet 1 kilometer away, 50°C. "Don't get caught, it is considered very offensive.", the colleagues said. Man-sized tires make a great target, though.
« Last Edit: March 30, 2021, 08:34:29 am by harerod »
