Author Topic: Inductor Help  (Read 542 times)
Offline bigjoncoopTopic starter
Inductor Help
« on: August 11, 2021, 03:36:09 am »
hey,
im trying to copy a lithium usb charging board based on the tp5000 ic..
im trying to design my own and have them assembled by jlbpcb since i can order a bunch and have them within 1 week instead of waiting a month..
ill post a picture of said board.
**the schematic and datasheet just show a 4.7uh inductor but no other specs.
but on jlcpcb parts inventory they have a bunch of 4.7uh smd inductors with different DC Resistance (DCR) and rated current...
im assuming i need one with a rated current of my circuit but what about the DC Resistance (DCR)???  they range from 19mega ohm to 500 mega ohm...
any ideas of which one would be best?
[ Specified attachment is not available ]
« Last Edit: August 11, 2021, 03:38:23 am by bigjoncoop »
Offline hagster
Re: Inductor Help
« Reply #1 on: August 11, 2021, 05:35:21 am »
Hopefully the DCR is in Milli ohms not Mega.
A lower DCR is more efficient.
You should also check the self resonant frequency SRF. This needs to be significantly higher than the switching frequency(800khz).
Offline james_s
Re: Inductor Help
« Reply #2 on: August 11, 2021, 06:07:16 am »
I think that's probably milli ohm, not mega. 500 megohms would be ridiculously high for an inductor. Assuming it's milliohms you want the lowest possible in most cases.
