The infallible capacitor is two in series, so that you have coverage if one shorts. Typically used going to an antenna/bias-tee or fuel tank probe to block hazardous DC from the IS section. A fuel tank can have large static electricity charges so a dissipating resistor would also be used.
The caps must pass the hi-pot test 6.3.13 of 500VRMS, be low enough capacitance value (one part) for spark energy with safety factor 1.5, and meet the separation distances across one capacitor. If the product is mains-powered the hi-pot requirement goes up.
So they are a large parts. I've used 500V ceramic caps but these are a bear for cellphone modems in antenna circuits, you have to use a microwave-spec'd part I find.
Certifier will apply 500VAC across one cap for 1 minute I recall, and 1,500VAC to GND.
